SP450andLE wrote:Simon! That hose is partially clean! What a disgrace!![]()
Doodling while talking on the phone.
Can assure you it's not clean now
phaedrus wrote:Hi Race, no I'm sorry I don't know about the turbo off-hand. I think mine's covered up too but will have a look and see what I can this w/end.
Your issue could still be timing, or some other issue with that inj pump. I made up an adapter to fit my dial gauge and timed it according to the book. Your description of problems is much like a timing fault. If it's too far retarded it will blow smoke and idle roughly, if it's advanced a little it will improve but can still be hard to start until it's right. To advance it you turn the pump away from the engine - possibly worth a try (it might be worth finding out what exactly your nephew did to the pump that made such a difference previously).
If I have time to get my tacho sorted I'll let you know what's needed.
Lucky you with the manual, my preference too but none available and I'd probably go Toyota on that anyway...
Cheers, P.
sibainmud wrote:R_ace-link wrote:
That TD27eti is out of a Mistral. They were the only ones to have a top mount intercooler, the R50 Terrano have a front mount cooler. I have retro fitted one of these coolers to my standard TD27t. See the similarities.
Your problem could be an injector. When it is running on 3, loosen each injector pipe in turn to see which cylinder is causing the issue. The one that makes no difference is the problem one. Eti engines have a sensor in number 1 injector that is hooked to the ecu.
PM TD Power, with the turbo and pump questions. He eats, breaths and shyts Nissan diesels![]()
I'll replace the injectors by the end of the month (I hope). only when cold starting it acts like it's running on 3 cylinders, but when hot it idles smooth, but you can feel a little hiccup though.
so it's a mistral engine![]()
does it differ from the terrano? like performance??? HP?? torque??
or is it the same engine![]()
do you know what turbo they used on these engines?
so I could start looking for a replacement, if I blow this one up
