AISIN WINCH
praduck
AISIN WINCH
Post by praduck »
Hi all . so i have a prado LJ78 and have brought a aisin winch .only thing is i dont know alot about them or what they are like....and i dont have a wiring plan for the winch making it a bit harder to fit . any INFO would be great thanks
keep it deep n go hard
kbushnz
Re: AISIN WINCH
Post by kbushnz »
Throw up a photo of it...
Depending which one it is it could be too small for the mighty Prado....
praduck
Re: AISIN WINCH
Post by praduck »
:D :D WELL THANKS .HERE ARE SOME PHOTOS.
ALSO SHOULD THE CABLE FEED OUT FROM THE TOP .
ANY INFO WOULD BE GREAT THANKS.........
kbushnz
Re: AISIN WINCH
Post by kbushnz »
Looks like they were fitted as factory options to the Prado.. And possibly the 80 series.
May have to find a manual online with winch info...
I have some manuals on my other pc which I will have a look at later in the week......
NJV6
Re: AISIN WINCH
Post by NJV6 »
Yes the cable goes on on the top which is the opposite to most winches.
Winch should be plenty strong enough, they a pretty good and well made unit. Like all AISIN stuff, it is nicely made. They run ATF in their winch gearboxes.
kbushnz
Re: AISIN WINCH
Post by kbushnz »
PM me your email and I will send you a section of the 80 series manual (pdf) which covers the electric winch and I will also try and pull out the electrical wiring diagram section for it also.....
Rural53
Re: AISIN WINCH
Post by Rural53 »
What ever you do don't flick the winch from in to out, or vise versa, without letting the motor stop fully, otherwise you will break the input shaft. Ask me how I know? Good news is any parts required are available from Toyota. Based on the free spool lever this is a later model one.
praduck
Re: AISIN WINCH
Post by praduck »
WELL GUYS THANKS VERY MUCH FOR THE INFO :D :D :D :D
HAVE TAKEN IT ALL ON BOARD....
adimw2
Re: AISIN WINCH
Post by adimw2 »
Current ride: 2002 L6 4.0 Jeep Wrangler
praduck
Re: AISIN WINCH
Post by praduck »
Hi all .. I would like to say thanks.. as i have been able to use all of your info and can now report back that the winch is on my garage bench and is working :D :D :D :D :D :D :D :D :D :D
kbushnz
Re: AISIN WINCH
Post by kbushnz »
Sweet now its time to fit it and try it on the trails.... :mrgreen:
praduck
Re: AISIN WINCH
Post by praduck »
Ok guys .spent the day remounting winch on to the truck ..got that done ...
Then started the rewire -- got that done so it would work off the remote
(in cab still to wire up) ..
Now heres the thing ---winch only works going in ..press remote to go out and nothing .makes funny noise and green light on remote dimes out...
Have i done something wrong as it was working on the garage bench..
Any thoughts
kbushnz
Re: AISIN WINCH
Post by kbushnz »
Check your wiring again...
I had a bad earth on my Warn....
The solenoids used the frame as an earth.... Newer ones have their own earth...
Sorry cant be of any more help......
praduck
Re: AISIN WINCH
Post by praduck »
thanks will do that on my next day off :mrgreen: :mrgreen:
pressy
Re: AISIN WINCH
Post by pressy »
hi dude,
i had the same problem when i was stuck the other day, and have since found the drum side was bent outwards and was jamming under load to the side of the motor housing, have yet to fit back together to test. just food for thought.
pressy
praduck
Re: AISIN WINCH
Post by praduck »
thanks man :D . am hopping to get sunday off work to try and sort this out..
praduck
Re: AISIN WINCH
Post by praduck »
was able to get the day off work ..
winch was main job for the day and was able to get it to work but only in --noy out ...when u press it out a solenoid makes funny sound and klicks.. i have replaced all the earth leads and cleaned up all the other lead ends..
mudlva
Re: AISIN WINCH
Post by mudlva »
Swap the cabling over on the solanoids if problems persists with the same solanoid then its stufffed and needs replacing
praduck
Re: AISIN WINCH
Post by praduck »
thanks will try that..
also can i remount the solanoids in the engine bay, or is this not good for the winch.
wjw
Re: AISIN WINCH
Post by wjw »
praduck wrote:thanks will try that..
It will be ok, providing you use decent sized cables.
Who knew Prados could fly?
praduck
Re: AISIN WINCH
Post by praduck »
well all . up date on winch . it is at the auto sparky as it has a short some were in the motor .The sparky picked the short up as it made a high pitch noise , he said that sounds like its to ground when you try to winch out ..Hope its a easy / cheep ish fix . :wink: :wink:
mudlva
Re: AISIN WINCH
Post by mudlva »
maaaate thats real handy
cheers :D
praduck
Re: AISIN WINCH
Post by praduck »
:D Cheers for the info .great stuff 8) 8)
Return to “Tool Shed”
