Surf steering???
brianr70
Surf steering???
Post by brianr70 »
can anyone help...my 91 Surf seems to have a lot more right hand lock than left hand, :shock: so doing left tight hand turns is a bit of a mission at times??? otherwise steering seems okay :!:
H2OLOVA
Post by H2OLOVA »
Check that the stop bolts haven't come loose on one side :wink: Other reasons are probably bent bits :cry:
Goose
Complete Plonker
Post by Goose »
could also be the arm on the steering box has moved (stripped shaft a little,or been moved before you bought it??) to a non-centred position, therefore giving you less turn one way, seen it before on a mitsi starion. If it is, it's an easy fix, remove the arm, figure out where the centre point in the box is, then reattach the arm...... easy peasy!! :wink:
"He who dies with the most toys wins!!"
jarps
Post by jarps »
my 94 steering box has no centre, it continuse , as I found out when i bent the spline in the arm when i hit a rut so it cant be out of center, just centered the steering wheel again. but a 91 might be different. agree that the steering stop things behind the wheel could be out?
Return to “Toyota”
