Del Fuego's Lada
Where all tihngs lada belong
Hoodoo
Re: Del Fuego's Lada
Post by Hoodoo »
Always good to hear of different ways of doing things. Keep it coming! :D
Regards,
not that I think that thing will ever legaly be driven on the road again but where the bullbar is going to sit is right in front of the headlights obstructing the beam, you might want to throw a few spotlights on the front if your going to be driving it in the dark :mrgreen:
Nivapulledout
Post by Nivapulledout »
sweet good work on the bumper so far mate. good to know with a bit of perseverance you can get those little bits out.
Del Fuego
Post by Del Fuego »
Quick update, had a sunny day so spent a good few hours on this little guy.
Much chopping of rear barwork to lighten it up and get it out of the way, will be much more minimal that previous, also started welding in some strengthening pieces... no pics of either but as you would expect the work is ugly but will do the job.. a bit like me really :/
Also started chopping away a big chunk of body work at the back/sides, there are a few reasons for this... namely cancer and the need to get the aforementioned barwork up and out of the way.
Pic: I ran out of cutting disks so cutting job unfinished but I'm sure you get the idea.
Also just to give you an idea of the previous rust "repairs" here is the front wheel well (looking back toward drivers door) with as much of the Space Invader as I could get to removed :/
And just for entertainment value (and to see what the clearance was like/how much chopping the guards need) I threw the new feet on... looking much more purposeful!
Before:
After:
Also did some sundry shopping/procuring pipe and such for snorkel, cable, connectors, antenna etc for CB random bits and bobs... Need to get more cutting disks so I can make some more noise/progress :D
Nivapulledout
good work.Looks pretty mean with those offset rims. keep the pics coming
ladeda
Post by ladeda »
choice bro gona be a mean little beasty.
Thats rust is looking nasty
keen to see how the back comes out once your done.
Del Fuego
Post by Del Fuego »
more or less done trimming the rear, neighbor came over and had a winge about all the grinding lol (really need to get a w/shop somewhere!) so finished that up for the day and welded a panel in to cover the massive hole. No pics of horrid welding but will post some when the rest of the holes are patched up... Pics for you sickos who enjoy lada :p
Before/during:
After:
still needs some tidying and will need notches cut still for where I want the barwork to end up but progress is being made :)
SP450andLE
Post by SP450andLE »
Del Fuego wrote:more or less done trimming the rear, neighbor came over and had a winge about all the grinding lol
Face+angle grinder=no more complaints.
Good work so far :D
ladeda
Post by ladeda »
Good work so far :D
blast the sterio up nice and loud that should drown out the sound of the grinder..... hey make it there choice, sterio or grinder :lol: :lol:
some one must of had nothing better to do with there weekend, next time hand them a sander and let em at it, youll be respraying the beastie in no time. :lol: :lol:
Del Fuego
Post by Del Fuego »
Yeah I was pretty pissed to be honest... come whinge at me about a few hours grinding... admittedly a couple days in a row, but always at reasonable hours... like 1pm - 5ish so as not to be a nuisance and he comes and has a cry. Yet the other neighbor (behind complainer) has had chippies in sawing and hammering every weekend for the last month starting at 7.30am sat and sunday doesn't get complained at grrr... the joy of living in "rich whiteyville" aka mission bay lol.
Oh well, he can keep complaining... work needs to be done and I don't know a quiet way :)
Yeah, I have some paint to try out actually... some rust killing paint stuff from bunnings, I know they use it in the states to good effect so will give it a shot... soon as i am done with all the cutting/welding/grinding... need to get much better at shaping the patches...
SP450andLE
Wow, I've been using the grinder until it's dark at home :lol:
Then again, I live in an area where "don't ask, don't tell" is the main rule for living
ladeda
Post by ladeda »
yea man next time he has a winge tell him hes must have you confused with someone who actually givs a sh@t..
whats the paint stuff your using called?
Im using por15 at the mo and finding it amazing!
O and heres a pic of the f ball joint spacers i got made up for $75 pair by a local guy on the shore,
Ha gave me a tip aswell how to make up some rear spring spacers for cheaper aswell so will do a little research there. but the fronts all finished now. getting onto the rock sliders now.
HEY does anyone have an old thermal carby spacer that goes between carb and inlet manifold lying around? Im tryna find another one..
keep up the work mate
SP450andLE
ladeda wrote:HEY does anyone have an old thermal carby spacer that goes between carb and inlet manifold lying around? Im tryna find another one..
I'll have a look next time I'm at my Dad's, I have all sorts of random bits lol
Del Fuego
Post by Del Fuego »
Ok advice please... I am in the process of thinking about installing a "snorkel" now the easiest (best as far as I can tell) way of doing this is to spin the aircleaner 180 degrees... everything still seems to line up ok doing this however it means the "crank case breathing system" aka a pipe coming out of the aircleaner on the passenger side which goes down into the fuel pump (im guessing?) no longer reaches...
is this actually important or is it just some sort of efficiency setup? If I am ok to remove/run without do I need to plug the holes, or am I better to leave them open?
Or... should I just put it back together the right way and work out another way i.e. run snorkel up drivers side...?
Edit: this thing
Smurf
Post by Smurf »
Needs to be attached, get another longer hose or join onto the original would be the easiest. Or move the fitting on the air cleaner. Other option is to run a longer flexi hose to your snorkel from the air cleaner in its original position
Cameron
Post by Cameron »
that just the engine breather.
have a measure up of the hose diameter and get a length from a hose place like HCD or something, and plumb it back to the air filter box or run it to a catch can.
SP450andLE
Mine just goes to a small oil breather filter of it's own. Used to go to nothing at all
Del Fuego
Post by Del Fuego »
Many thanks, I figured just replacing the hose with a longer one was the second easiest option but thought I should make sure it wasn't just a silly pointless thing... will go on a hose hunt, need to get some flexy/rubber thingo anyway so hopefully will be able to suss all at the same time.
ladeda
Post by ladeda »
buy the look of the thingo on top of the thingymewatsit. :lol:
I wonder if the 1700 filter box will has the same bolt patern as your 1600. if it does you can have mine as ill no longer need it and it has a better angle to the jandel.
The intake on mine points to the r side of engine bay so will be easier to plumb snorkel up to drivers side. and wont have to change the crank case breather as its the same.
Ill evin flick ya my carb for puck all if ya wana put a 1700 carby on there itll giv it heaps of grunt mate heaps :lol: :lol: :lol:
SP450andLE
Fairly sure the bolt pattern is the same, mine is the same as a 1.6 filter box I think.
And yeah Vince, chuck the 1.7 carby on. You can use my Lada as a reference. Dooooo eeeet!
(I'm fairly sure the 1.7 carb does actually make a difference over the 1.6 one :lol: )
Del Fuego
Post by Del Fuego »
hmmmm... that would be a very useful thing there with the thingo pointing the other way... I would love to remove this from your stack of stuffs lol
Carb... hmmm I currently have a running Lada, that I just need to bolt/weld/cut things onto/off... I suspect changing the carb would leave me with a non running lada knowing my luck... I do like the idea of even a little more powahhhhhh though...
Damn you and all of your putting of ideas in my noggin
ladeda
Post by ladeda »
shouldn't be too hard to swap carbs.
we worked out sp has 1700 one on his 1600 so if between us we cant figure out where all the the widgets and gadgets go, can just look at his.
wont be an issue tho mate not much to em and the one that came off mine was working fine iv just gone to weber now. I believe the 1700 carb is a copy of the solex carb and according to the weber guy up silverdale he recons there not to bad a carb either.
hey check out trade me there is another lada come on ther body looks prity tidy might be worth it, prob would be easier to fix a bit of rust in the sills than going to the extent yours is at and its got wor and reg. 1 dolla reserve.
just another idea for ya noggin :lol: :D
SP450andLE
^ bidded on that one a couple of times, someone has an autobid though :(
Oh and Vince, maybe just stick with the 1.6 carb for now, if you find you need more powah then you can probably chuck a 1.7 carby on.
Just get this thing going! :D
Del Fuego
Post by Del Fuego »
Bloody hell, dude pulled the auction/will relist it next week lol
and yes I suspect for now just the 1.7 cleaner will be fine so I can rangi up a snorkel on the cheaps :) and get the bloody thing dirty... I must stop looking at it, having a ciggie, undoing things... bolting them back on... sitting down, looking at it some more... ciggie... repeat lol. Progress must be made this is getting silly
Ladeda... lemme know how i can get a hold of your box ;) lol... aircleaner thingamawhosit...
ladeda
Post by ladeda »
hey sp450 recon i could borrow ya muddies so i can start susing the wheel arches.
I recon im gona grab a guard roller and flair the crap outa them should look ok when fin and will eliminate the need for the rubber flairs
weber = shed loads more grunt what a difference it made now, like del fuego I gotta sort out a snorkel and air box to suit.
SP450andLE
Yeah man, they aren't going far atm. Although I did just make a storage unit to fit around them this afternoon :roll: :lol:
Gimme a txt/pm when you wanna collect them. Saturday during the day should be sweet for me
SP450andLE
Ooh ooh ooh, a mate of mine just told me that there's a niva at pickapart takanini. May still be some good parts on it?
Del Fuego
Post by Del Fuego »
damn, wish I had read this before I started work... was in Manukau already picking up some steel...
hmmm... may have to go for a looksee on the weekend... this means however that i will succeed in getting not a damned thing done on the truck lol.
Don't even know that I need anything haha
ladeda
Post by ladeda »
if ya do go down let me know if its still got:
front cv shafts. alwase good to have spairs.
rear diff. so i can set up front independantly supported diff with steel case
transfer case. so I can make up a rock crawler transfer box.
drive shafts. good for spairs as well.
steering box. to have spair as these wear out with bigger tyres on
SP450andLE
^ You have basically described a section of my parts collection. I'll have a look and see how many parts I have. I think I have 2 full diffs, one part-disassembled one, about 2 or 3 TCs, a bunch of driveshafts, some old crap cvs, and maybe a steering box? I should really write down all the bits I have.
I'd be keen on doing some sort of a deal where if you guys need anyhting you can take it, and either give me a little bit of money, or source a replacement and buy that for me (at some stage after taking my one, it doesn't have to be straight away though).
Keen?
Return to “Lada”
