Body lift bolts - Help
fullthrottle
- Shuttle Queen
Hi All
I'm having all sorts of trouble tracking down the two rear M12 bolts for a 50mm body lift. Can anyone advise where I could obtain the following:
160mm bolt (Shank + thread length)
High Tencile
1.25 thread pitch
Passivated Zinc plated
The problem seems to be the thread pitch because it is very uncommon.
Options I have so far..
1) Use a length of threaded rod instead.
2) Try and get a longer bolt with a shank at least 160mm long. Cut off the exiting thread and cut a 1.25 thread down it.
Ants
High Tencile
1.25 thread pitch
Ants
- mud_slinger
fullthrottle
- Shuttle Queen
Re: Body lift bolts - Help
mud_slinger wrote:have you tried blacks fasteners?
Cheers, yeah just gave them a call. Everyone seems to do a 150mm max length. Atom, SteelandTube, Fortress etc etc.
Seems to be that thread pitch which is the issue.
- mud_slinger
steel and tube? i dont know if they do them or not tho
needs more curry
0272593533
0272593533
1) you can definatly get hi-ten studding, not sure if in metric fine.
3)possibly) if your gonna stuff round and cut a thread (hopefully not with a die nut) why not make a stud out of 12 dia 4140? I have a feeling 4340 would be excessive but happy to be wrong.
Tow bars on wakefield st have them
fullthrottle
- Shuttle Queen
stinky wrote:Tow bars on wakefield st have them
Sounds bloody good. Will give you a shout tomorrow.and hopefully collect.
Any reason you couldn't go for a 1.5 pitch thread, and use 1.5 nut?
I must be missing something?
fullthrottle
- Shuttle Queen
slide wrote:Any reason you couldn't go for a 1.5 pitch thread, and use 1.5 nut?
Yeah, its a captive nut it needs to go in.
If ur stuck let me know, theres a place I used to go to (prev employment) that source the fiddly bits, and they sell to "Blacks" (turns out they are a 2nd middle man). N when U need it "now/today", "they" will send you round to their suppliers if its not in stock
Sounds like stinky has it sorted. But there's also Coastal fasteners in Porirua and they have a shop in town as well.
85 Hilux single cab
02 Grand Vitara
02 Grand Vitara
- mayhem1982
i had to go stainless bolts to get mine sorted
fullthrottle
- Shuttle Queen
Tarmac wrote:If ur stuck let me know, theres a place I used to go to (prev employment) that source the fiddly bits, and they sell to "Blacks" (turns out they are a 2nd middle man). N when U need it "now/today", "they" will send you round to their suppliers if its not in stock
Hello
TAZ is going to have a look for me, but could I take you up on your offer to see if they can supply such a bolt?
Thanks
Ants
Remove the captive nut and replace with 1.5 pitch nut and bolt. Few hits with a cold chissel and it should be out.
MWB V8 Safari Ute
fullthrottle
- Shuttle Queen
doddzee wrote:Remove the captive nut and replace with 1.5 pitch nut and bolt. Few hits with a cold chissel and it should be out.
Hi
It is one option I'm considering. That captive nut is welded in between the outer and inner skins of the body. So one option Stinky gave me was to cut a hole in the floor to reach the nut. Drill out the thread and then insert a new bolt with a 1.5 thread
Cheers for the advice
Sketchy_Racer
Hey mate,
Costal Fasteners out in Porirua have them or can get them overnight, I know as this is where I sourced mine for when I did the body lift on my Terrano.
fullthrottle
- Shuttle Queen
Sketchy_Racer wrote:Hey mate,
Very interesting. I spoke to them and they couldn't help.
Are your bolts 160mm long?
Ants
Sketchy_Racer
Mine were long enough to do a 50mm body lift, which I guess means they were 150s not 160s. What size body lift did you do?
fullthrottle
- Shuttle Queen
I'm doing a 50mm lift. just measured the existing bolts and added 50mm to them.
But hey if 150 works for you it should for me. I will take a looky.
fullthrottle
- Shuttle Queen
Ok conclusion to this......
A 150mm bolt will work. only gets 10mm into the captive nut though.
hi i got mine from micho metals in dunedin they ordered them in for me in metric fine at 150mm (was the longest he could get for me ) but in my terrano it was easy long enough was ment to be 160mm as well
