I need a vitara diff head
For all Suzuki related topics
boosted zuk
Post by boosted zuk »
Hi there guys. I'm looking for a 1600 vitara/escudo diff head. Its auto and the ratio is 4.62. I have 5.125s but they are to low for me. I need one front diff. Already have the other. :P :P
I'm in the chch area
Also here's a link to my buildups
http://www.auszookers.com/forum/viewtop ... t=Lbs+zook
O an I will add them to this forum just haven't had the time.. :oops:
Cheers Albie
tomsoffroad
Flopsie
Re: I need a vitara diff head
Post by tomsoffroad »
Just read thru your build thread. Nice work :wink: Reminds me of when I was your age :lol: Chuck it up on ORE, there's alot of Zuk lover here which Im sure would like to see it.
muduki
Post by muduki »
I have two front diffs not sure of ratios tho!
churchill
Post by churchill »
Ive got 4.875 front and rear if they're any use to you. They're V6 but the vacuum disconnect has been removed and replaced with a 22 spline head.
boosted zuk
muduki wrote:I have two front diffs not sure of ratios tho!
It's gota be out of the 3 speed auto I just found out.. 1988 to 92 I'm pretty sure.. :wink:
boosted zuk
churchill wrote:Ive got 4.875 front and rear if they're any use to you. They're V6 but the vacuum disconnect has been removed and replaced with a 22 spline head.
Thanks for the offer. But I would need two front 4.8s.. As you can't run the rear vitara diff in the samurai.. It's to big.. And I found that out the hard way.. :oops: :roll:
Rotazuk
Post by Rotazuk »
If you have a 4.6 rear I would cut up a 413 and vitara rear housing and run the big diff in the rear .
churchill
Post by churchill »
No worries, they're on the shelf if you need them.
Return to “Suzuki”
