A Frames
Discussions concerning land access, DOC legislation and 4wd regulations
pouw
A Frames
Post by pouw »
Anyone know the regulations relating to have an A framed 4wd?
Specifically interested in whether the A framed vehicle has to be registered and/or warranted.
1986 2.5L TD Pajero
bruntonjm
Re: A Frames
Post by bruntonjm »
as long as the a frame is properly attached, and well built on a reasonably safe and sturdy vechle there is no need for the vechile being a framed to be warrented or registered. i had a print out from ltnz i used to keep in the glove box.
pouw
Re: A Frames
Post by pouw »
Excellent, thanks for that mate, thats what I wanted to hear :)
1986 2.5L TD Pajero
DA RAM
Re: A Frames
Post by DA RAM »
with the A frame i used to tow DA RAM behind my motorhome needed 2 saftey chains at ball because i was towing 2000 +kgs BUT ALL A FRAMES need a saftey chain on each arm at other end!
and i think ????? your still limited to 80 ks 8)
GO HARD OR GO HOME !
2015 JK Rubicon
007
Re: A Frames
Post by 007 »
I looked into this a wile ago, you don't WOF or ergo , I think you still need lights and you can block your plate (get a boat light bar for the back).
There is an issue with Maximum un braked towing weight for most vehicles is 750kg. Not that I would worry about that.
ford ranger wildtract and sj.
Return to “Land Access / DOC legislation / Regulations”
