Are the starters from the L series engines interchangable
eg, will one from a 2Lt fit in a 3L (2. 8 )?
Cheers Sam
L series Starter motor info
pos nissan patrol
Ln106 single cab
Ln106 single cab
Re: L series Starter motor info
I think so. Check the tooth count on the gear that engages the flywheel. Until recently I used a 2L startermotor on my 5L motor
Nick
Nick
85 Hilux single cab
02 Grand Vitara
02 Grand Vitara
yes.
just be careful as the 2lt one draws more current and has a bigger connector then the 3l starter.
Also it depends what it comes out of.3l vans have a smaller starter from memory
Rob
Rob
afaik all the 3l ones are the same size. i can't see why toyota would spend $$ making a different starter for the vans.
Oh your right .turned out to be a 2lte starter that was bolted upto a 3l
Rob
Rob
