whos broken a d35c ?
spanky
Post by spanky »
read alot of different stories about these diffs on the web, but just how weak are they?.if you have broken one,how?, what size tyres ?, locked diff?, cheers.
vaughan
yeti
Bruiser
Re: whos broken a d35c ?
Post by yeti »
heard the stories as well...the 30 in the front is worse...just gotta pick ya line better....the old xj had 33s didn't brake it...but that's in mud and rivers...rocks be different but...just gotta be wise as in when to give it the slipper.....cheap enough to replace anyways........ :wink:
v8 tj...luvs the gas......
TJ
Post by TJ »
New Zealand new TJs came with Dana 44 rear ends. As such you won't find many with broken D35s (there are some imports that did/do come with D35c).
Could this problem be limited to XJs then? I don't know enough about XJs (no experience with them).
spanky
Post by spanky »
i think some xj's came with the 44, but not the jap spec ones like most in nz.i will lock mine and see how it goes, will start looking for some spares ,only running 31's, if they are weak what do you put in it's place?.ford 8 or 9 inch will be my pick.
TJ
Post by TJ »
spanky wrote:i think some xj's came with the 44, but not the jap spec ones like most in nz.i will lock mine and see how it goes, will start looking for some spares ,only running 31's, if they are weak what do you put in it's place?.ford 8 or 9 inch will be my pick.
Or TJ D44. Same width.
yeti
Bruiser
Post by yeti »
came out with 8.25 ..stronger the yanks say....popular swap over there is outta a explorer..was doing some digging on this before i sold it...will dig some info up after work.......still got a 35 sitting in the shed...what kinda shit ya gonna be doing in it......
yeti
Bruiser
Post by yeti »
here ya go...links in this link....the aussie do it as well.....
http://www.ausjeepoffroad.com/forum/sho ... p?t=106763
dont know how hard it would be to find a d44 here..........i think crazy bastared on here has killed one...
http://www.offroadexpress.co.nz/Forums/ ... 32&t=29490
was the front...
spanky
Post by spanky »
the only problem with the explorer diff is then would have to buy gears for the front diff to match, will look for a d35c to have as a spare incase it breaks when i lock it, in nz is probaly easier to use d44 or 9 inch i think.
yeti
Bruiser
Post by yeti »
coolies mate..lets us know how ya get on....... :wink:
bernie
Post by bernie »
I got at Jeep wrangler with the 35C in the back and a Hi pinion 30 up front, running 33” TSLs now on Silverstone’s. It’s a dedicated bush truck; she has also completed probably 10 or 12 winch challenges with no axle issues.
In saying that:
The axles are small light weight thing’s for sure and the yanks hate them with a passion. The weakest link on the rear is the spider gears, you can combat that by installing a locker, and the next weakest link is the carrier itself, so you install the type of locker that has its own carrier i.e. Detroit or ARB. Don’t know about the axles as I never used them, I opted for the “molly full floating” units. My advice; if doing serous off road and you want to keep the 35, do a gear change, on 33” at least a 4.1; 4.56 probably better and when you do that go for a solid pinion spacer rather than the “crush sleeve” The housing can also benefit from using a “truss”.
The problem I see with a Ford axle is they are big, the 8.8 is bigger than the Dana 44, weight is not an issue, it’s just their physical size, they are Hugh in comparison to a 35. As for the 9” the pinion is too low for the drive shaft length if you are installing into a wrangler (in my opinion). They are a tuff axle and you will be going to break one, but in my opinion you will end up dragging its arse everywhere if you use a Ford axle.
In short, a 35 is doable but it will cost a couple of bucks and you will need to drive it accordingly. If you go the Dana 44 way, you still gotta spend the same on a locker but I would think the axles themselves would be ok. If you like big tires and the throttle and rooster tails use the Ford axle.
The “Hi pinion” 30 up front is a surprisingly tuff little thing, again, with molly axles and a locker, no known issues, the only axle I broke was a STD one and that was quite a few years ago, actually I broke the UJ, that in turn took out the axle. I recon you will be going to break a 35 or a 30 on 31s driven accordingly.
My 2 cents worth
Bernie
spanky
Post by spanky »
thanks for that :D ,will get a spare 35 and start saving for the 44 and go that way, would love to gear it down but wont be this year, keeps it all mopar too.cheers.
yeti
Bruiser
Post by yeti »
can always throw some darkside shit under it... 8)
spanky
Post by spanky »
yeti wrote:can always throw some darkside shit under it... 8)
that looks like the hit 8)
Return to “Jeep”
