WTD Urgently Samurai / SJ413 driveshaft
Blew a uni and it damaged the ears on the yoke so I need another driveshaft ASAP. Any help would be appreciated.
Re: WTD Urgently Samurai driveshaft
What end of the drive shaft????
May have something that might work. I have a drive shaft with a busted rear yoke after a spring breakage, but a good front yoke.
If its the front joint of the rear shaft that's crapped out on yours, you may be able to just pull it apart at the slip joint and plug the good end of this one into it??
DieselBoy wrote:What end of the drive shaft????
Sounds farken good to me
Anyone? Can't really afford Mudbits pricing
- Rotazuk
Do you mean the bit that bolts to the diff ? if so you will have to find one . if its any other part you should be able to fit a 413 part . 413 , samurai and vitara all run the same size uj so you should be able to mix and match .
Can the holes just be drilled out to 10mm? The shaft I have is a 413.
Rotazuk wrote:Do you mean the bit that bolts to the diff ? if so you will have to find one . if its any other part you should be able to fit a 413 part . 413 , samurai and vitara all run the same size uj so you should be able to mix and match .
Thanks, I need the female end, the bit that bolts to the transfer is fine but the other side isn't. Seeing as 413's have a transfer mounted handbrake will it be shorter?
- Rotazuk
No , from memory the t/case without the brake has a flange that takes up the same space as the drum brake drum that the shaft mounts to .
All my stuff is in storage so ask someone to measure each one . I think they are the same length thou . I would be looking for a 413 shaft end and swapping your diff flange over if its still good .
Chris
Chris
- Rotazuk
That should be the same no matter what the length , you could get one off a front or rear shaft . Think I biffed all mine but will have a look when I go to the storage this arvo .
Chris
Chris
I'm waiting !:mrgreen:
Re: WTD Urgently Samurai / SJ413 driveshaft
Someone must have something? really need this cause I can't go 4wding till I have one
