24v cruiser 12volt compressor?
ski
Post by ski »
I have a 24volt 70 cruiser. I am looking at a 12volt portable compressor,don,t want to buy a24volt compressor as I may sell truck later.Question what do I have to do to run a 12v compressor straight off the battery ?. Compressor draws 50 amps under load.
mudlva
Re: 24v cruiser 12volt compressor?
Post by mudlva »
ski wrote:I have a 24volt 70 cruiser. I am looking at a 12volt portable compressor,don,t want to buy a24volt compressor as I may sell truck later.Question what do I have to do to run a 12v compressor straight off the battery ?. Compressor draws 50 amps under load.
get a 24 to 12 v reducer drawing off one side at those amps will not be good for the battery
Henry
Post by Henry »
Hi
at 50 amps you will struggle to find a 24v to 12v reducer.....
It is not good to just hook it up to 1 battery. the draw off just one battery will eventually stuff one or both batterys as the charger tries to charge things..
ski
Post by ski »
thanks for the replys,I was thinking of 1 battery for 2 tyres an then swapping over to the second battery for the other 2 tyres////.Cheers :roll:
suparoo
Stropper
Post by suparoo »
You need to buy a battery equaliser and then just hook it across one battery.
http://redarc.com.au/products-and-servi ... -equaliser
Return to “Tool Shed”
