Kiwipete and Elmos Culverdon to Cheviot trip
Links to 4wd video clips etc. Link from other sites or upload to our gallery and post the link here.
Elmo
Post by Elmo »
http://www.youtube.com/watch?v=eANpNtxm--g
11meg vid, 3 mins 30ish long.
Video'd with a cheap web cam attached to the L/H mirror of Elmos Saf.
Shows some time cruising round the hills, a little bit of mud, and some playing at the Waipara on the way home.
The first lil bit of the vid is a little unclear as I didnt have the colours set right.
No sound of the trip, but there is a music overlay which is Nessaja, by Scooter.
Enjoy.
Ken
Elmo
Post by Elmo »
Its LIVE!!
kiwipete
Post by kiwipete »
Loads no probs at alle here, great vid indeed considering how it was made.
Amasing what a little bit of kiwi ingenuity can achieve.
And to think it was splatterd with mud, none getting on the lense.
What is needed now is several planted on the truck with a selector switch to choose which one to use.
Ph 0212078472
billyvanboheman
Post by billyvanboheman »
Very stunning, great job Elmo, really enjoyed the soundtrack as well, I am keen to catch up and have a look at the setup, or maybe you could give us all a run down on what you put together down the cable from the web cam to achieve such great results. 8) 8)
Elmo
Post by Elmo »
Web cam = http://www.geniusnet.com/geniusOnline/o ... ubId=30912
Cam at the bottom, its MUCH smaller than the pic. not much bigger than the stricker side of a match box really. Bracket was clipped under the glass of the L/H mirror, adjusted mirror to jam on it really. And added a little bit of tape for supprt.
Lead fed directly to a USB extension lead and into the laptop.
Recored at 320x240 I think. At not the highest resolution either.
Used software that came with the cam to record.
Changes I will be making.
How I mount the camera, want it to be more flexible with locations, ie on a suction base, or similar.
Sound, easy enough, just ad a mic, with the right recording software.
And recording software, it appears Microsoft movie maker can actually capture video as well, with sound. So will try that next.
Camera cost me $35, thats with a little discount, was $49.99 at Bond and Bond.
kiwipete
Post by kiwipete »
Here's a robust unit that looks like it would be great for off roading.
http://www.trademe.co.nz/Electronics-ph ... 403307.htm
Capture size: 1280x960
Transmission rate 640x480 @ 30 F/s 1280x960 @ 10-15 F/s
1.3 Mega Pixels
USB 1.1/2.0 compatible
auto color correction
auto brightness adjustment
adjustable focus
Ph 0212078472
Elmo
Post by Elmo »
Yeah, sounds like a good one. Might have to look into getting something like that.
Now that I know its going to work that is.
billyvanboheman
Ya got me all enthused now, dragged out the old laptop to see what can be done with it, it might struggle to upgrade from Windows95 :shock: to even 98 I think, time for a clean up and see :lol:
Elmo
Post by Elmo »
Im sure as ;png as you can get the right software on it (most cams come with atleast 98 drivers, some may have 95, but thats a diff type of operating system) then Im sure it will capture video just fine.
You'll prolly have to turn the the frame rate down, but even 15 frames a second is fine.
Just process it on ya pc.
billyvanboheman
Yeah, will see how I go, it's an old x work unit so just removing some of the dead wood and checking out system info, got it for my daughter to use but did you know, if it's not the latest model it's not up to scratch :shock:
Oh well her loss my gain, untill I have to get a new one for her :( :cry:
kiwipete
Post by kiwipete »
Think i'll hold off getting one for now and see what is available in Thailand at Xmas time. Might save me a dollar or two. :wink:
Ph 0212078472
Return to “Video Clips”
