60 series PTO winch
jex_the_bug
60 series PTO winch
Post by jex_the_bug »
pto winch and bumper from my old 60 series. very strong winch, worked well but have two and need to clean out the shed. has wire rope and think the input shaft from the gearbox is all there to.
$400.
pickup queenstown.
mudlva
Re: 60 series PTO winch
Post by mudlva »
Shark wrote:Hey mate,
What year 60 series is this from??
Is it a complete kit?? If not what else is needed to make it complete.
Marc
dont matter on the year as they will all fit
mudlva
Post by mudlva »
oh yeah check the trans box to make sure its got the pto drive sprocket installed as some imports came out with out the pto sprocket
Shark wrote:Mine is a 85 5 speed, just trying to work out if it will fit..
Im led to believe the PTO drive box is different between the years.
Shark wrote:Hey there, new to the site.
Was lurking around the net looking for a PTO for my 4wd and came across this site and thought i would join up :D
I drive a 1985 Nissan patrol cab chassis. Its had quite a bit of work done, running a garrett 2860, FMIC, twin ARB air lockers, Bf goodrich KM2 (35's),
3" mandrel bent exhaust and heaps of other goodies all built by me:)
would I be right in thinking you've got a Nissan and not a 60 series landcruiser? :D
Shark wrote:Facepalm... dammit..
Thought 60 series patrol :oops:
MK/MQ pto winches are slightly different to GQ's, the top pic is a wider MK/MQ winch and the bottom pic is a GQ, you can make them fit by shifting the mounts around a bit, dunno if the PTO shafts and PTO drives are the same or not? :mrgreen:
crazyclark31
Post by crazyclark31 »
off topic i know but
The landcruiser winch fits on safaris pretty easily. had one on my last safari. just need the output box for the side of the gearbox and the lever kit
JONO250
Post by JONO250 »
where abouts are you based?
jex_the_bug
still have it,
got some photos too.
jex_the_bug
still have it
IcedJohnno
Trailer Trash
Post by IcedJohnno »
Do you have the output box that bolts to the transfer case? The drive shaft goes into it.
jex_the_bug
no sorry, not the bit thats part of the gear box
