Home made snorkel 4 Isuzu Bighorn
billyvanboheman
Post by billyvanboheman »
Started the snorkel project on the Isuzu tonight, started with the planning but couldnt help taking things out. :lol:
These are the before photos of the inside and outside.
Image[/img]
And of course I ended up with the bits left over after putting the grille back on (more leftovers than normal though I think) :shock:
Next step is to find time over the next couple of weekends to move the power steer reservoir and block off the old air intake on the filter housing and replace it with an inlet at the back.
It's my weekly driver when I'm not on the bike so cant have it in bits for too long.
More to follow.
Last edited by billyvanboheman on Sat Oct 07, 2006 8:26 pm, edited 2 times in total.
MATT4U
Post by MATT4U »
Steve (supralux) has one for a bighorn all ready to go, airbox and all
billyvanboheman
I knew there was one on the one he had, did not know if he had it still or not but what could be more fun than building it yourself 8)
I enjoy the build as well as the result. :roll:
billyvanboheman
Update,
On Thursday evening removed the air filter assembly and took out some more surplus pipe work, got the hose to move the power steer reservoir from the good buggers at BNT (another unadulterated plug as I shoot with one of the guys who works there) and will hopefully hook into repositioning the reservoir tonight, the next hold up is I went and priced a hole saw to cut 2 1/2 inch hole in the inner guard, seems a bit much to drill two holes!!!! Anyone got one they might like to lend for a weekend afternoon? I would be very careful with it.
Here is where I am up to.
Image[/img]
More to follow.
Mattman
Post by Mattman »
Rather than block off the inlet on the air filter housing can you rotate it so that it's in the correct position to go out through the inner guard?
You might be able to get away with a jigsaw to cut the holes.
Matt.
billyvanboheman
Thanks for the Idea of rotating the filter housing, but Mr Isuzu made a good job of welding all the pretty rubber mounted brackets to the filter housing assembly.
It's not a problem to blank and reposition the inlet, besides I need the welding practice with the mig on thin metal.
As for jigsaw I might resort to that as I have one here, but it will only be if I can’t find a hole saw to do the job.
billyvanboheman
Update.
As per this weekends achievements 7/8th October string.
Power steer reservoir moved and air filter housing cut at both ends for blanking of old and welding in new inlet tube.
Used a jigsaw for the hole in the filter housing, but after doing that worked out it will not work on the outer or inner guard due to lack of room.
Here are the pics.
4wdnuts
Post by 4wdnuts »
i brought a set of holesaws from bunnings and they were bloody usless. in the end i just marked the circle and got a drill bit and drilled holes in a circle and got one of them bits that cuts sideways to clean it all up with. takes abit longer but you get there in the end and looks just as tidy.
billyvanboheman
I did at one stage have a set of those multiple band hole saws, if these are the ones you were talking about, metal carrier with slots round it for different size hole saw bands, and centre drill.
If this sounds like the one you are talking about I agree, OK for wood but even then at a stretch.
On metal hopeless, the one I was checking out at Bunning’s was single 2 1/2 inch size and then you had to buy centre carrier separate as well, about $70.00 for the one set up to cut two holes.
I will keep looking I think. :roll:
billyvanboheman
Also forgot to mention this is a shot of all the extra pieces I no longer need, a few more than usual!! :shock: :D
billyvanboheman
Snorkel update.
Spent some time in Mayfield on Saturday, now have an airfilter housing that looks like this.
And in place awaiting the snorkel tube.
All bolted back in.
Still more to follow...........
4wdnuts
Post by 4wdnuts »
looking good! found a hole saw yet? your more than welcome to try mine but as i said more suitable for wood. they are actual solid holesaws. maybe if i used a bit of lubricant it mite have cut better :roll:
billyvanboheman
Update time.
Not much progress lately due to all that nasty work stuff!!
Got game this weekend though and cut some holes in the panel work.
I'm doing mine the wrong way round and cutting the holes and making a wire template for the benders to scan.
This is due to my snorkel being longer than the one they had on file.
Here are the latest photos.
Maddog
Post by Maddog »
hi billy
Looks like you are doing a nice job, it looks very similar to the work that has been done to mine, heres some pics of mine to compare .
96 Bighorn Irmscher Lwb 3.1 - standard
previous 4WDs
93 Hilux surf
92 Isuzu Bighorn Irmscher 2.8 ,SWB, 122k,lifted, other mods
91 V6 Surf
billyvanboheman
Time for a very long overdue update.
I spent some time at the workshop over the weekend and turned these
3 inch stainless :shock:
into this
So just a bit of cleaning of the welds to sort, and the mounting brackets and connecting hose for the air cleaner 8) .
And after looking at this post again for the first time in ages, I realised its coming up on a YEAR since I started this :shock:
I really need to pull finger and get it finished before the 26th :?
Steve_t647
Post by Steve_t647 »
billyvanboheman wrote: I realised its coming up on a YEAR since I started this :shock:
Makes me think I am not so bad with my rears up front but I am still collecting bits :oops:
dazza85
Post by dazza85 »
Billy, what is the angles on the second and third bends ??
I am thinking seriously about making one and am thinking that if you have already worked out the angles it is looking easier and easier
billyvanboheman
dazza85 wrote:Billy, what is the angles on the second and third bends ??
Whats an angle :?: :?: :?
Seriously I couldn't tell you, it was made from 1x 90 deg bend, cut in half and cut to fit by eye :!: :roll:
Sorry I can't be more help.
Ryan
Post by Ryan »
billyvanboheman wrote:Time for a very long overdue update.
into this
nice work :thumleft:
looks alot like mine did!! :D
MAHINDRACJ4A
Post by MAHINDRACJ4A »
thats pretty cool, i may have off missed it but how much money did you save compared to an off the self product ?
1977 Mahindra CJ4A - 1GGTE 260hp Supra Engine - 3" Lift
billyvanboheman
Also forgot to mention that the hole in the guard may have got a very small bit larger :shock:
billyvanboheman
Well finally some progress has been made :roll:
Here's a shot from the weekend, which shows the addition of a large piece of pipe that's now 1/2 mounted to the vehicle :wink:
Just gota sort the bracket to mount it to the pillar, hopefully this will be done by the end of the week, then some cosmetic cleaning to make it pretty, and a hose to join to the air filter housing, and it's done, FINALLY :oops:
MATT4U
Post by MATT4U »
Posted: Tue Sep 26, 2006 11:42 pm
:lol: :lol:
billyvanboheman
:lol: :lol:
Yeah Yeah, I know :lol: my next aim is to finish a mod in under a year :roll:
I was thinking about this one :!:
Electric Fan Mod
Start date Sun Apr 22, 2007 10:32 pm :!: :!:
snorkel
angles for snork's mine on the saf were 45 dec is that any help, think most trucks have the same screen angle
Steve_t647
You tested the snorkle out up worsley's? :lol:
I think you have the wrong idea about snorkles :oops:
Kidding Billy it looks good are you going to paint it the same colour as the car?
billyvanboheman
Steve_t647 wrote: are you going to paint it the same colour as the car?
Um, I hope not, it's stainless, so if I can make the stainless welds look pretty, I will leave it shiney 8)
Steve_t647
The hole got bigger to allow for the bend in the pipe right? My hole got bigger too and then there was a little gap at the front :oops: tricky little bugger those.
But nothing the black door edge material couldn't close up :)
Good luck with the polished Stainless look and for the wedding next year.
squeak
Post by squeak »
my snorkel.
i moved my air box to the back corner, figured it was easyer for me as i was too lazy to cut and weld my airbox.
I've got a Bighorn ... . . . .
027 360 1985
