Runs pretty sweet, but has become just about impossible to start when cold.
So with my limited knowledge and the help of google I started looking at the glow plug system for problems.
Pulled all of the glow plugs out and tested them - all glowed orange straight away.
Used a test light on the lead that powers the glow plugs while flicking the ignition on and off, it appears no power is getting there. (glow plug light on dash flicks on then off as normal).
I think I have located the glow plug relay, i can hear it clicking when I turn the ignition on, and so I opened it up thinking something might be obviously wrong with it... looks fine now ive got to seal it up somehow
After I had flattened a battery trying to get it going and then did all of the above, i recharged the battery and disconected the glow plug rail and conecected it straight to the battery for a couple of seconds and it started straight away without hardly even turning over.
So what to check now? there must be a reason that the glow plugs are not getting power, what is it that tells them to turn on/off? Is there a controller and timer somewhere?
What other components are there in a glow plug system?
Any help appreciated, seems like the best place to come to
