1997 TJ Auto trans cooler question.
brakes-shocks-lockers-etc
Jeeper
Post by Jeeper »
I am noticing water dripping at a pretty constant rate during and for about 30 mins after driving. Its coming from between the sump and the trans up high somewhere. Its definately water as there is no smell or viscocity to the fluid. I have no idea where it may be coming from - And this is a rookie comment but the trans is oil coiled right??
Jeeper
Re: 1997 TJ Auto trans cooler question.
Post by Jeeper »
"Oil cooled"
Henry
Post by Henry »
Hi
Have you had the Air Conditioner on? they often dribble after a trip?
Jeeper
Post by Jeeper »
I dont have Air con so it wont be that but I did find a post from a guy over on Wrangler forum with exactly the same issue (and pics).
http://www.wranglerforum.com/f5/help-wi ... 48456.html
yeti
Bruiser
Post by yeti »
yuk if its the froze plug at the back of ........
v8 tj...luvs the gas......
TJ
Post by TJ »
There is cowl drain in that area. It could be rain water or condensation. Transmission lines are on the passenger side, not middle of the engine. Factory cooler is at the nottom of radiator.
