V8 blowen coiled LN106
imsohi
Post by imsohi »
Hi all just got some pics togeather of my build its been in the process for about 3 years and been rebuild 3 times in this time done one unsucessful compitetion so now im doing it properly.
Pulling her down and Making template for rear deck
Picking up the truck from Whataroa $1600 steal
DA RAM
Re: V8 blowen coiled LN106
Post by DA RAM »
looks like a bit of a dunga wheres some up to date pic's :mrgreen:
GO HARD OR GO HOME !
2015 JK Rubicon
imsohi
Post by imsohi »
Wait till the end :lol:
Rebuild of the rear end
Lexus V8
Lexus V8
T-Boon
Post by T-Boon »
Front coils only ?
To Boon or not to Boon.
imsohi
Post by imsohi »
Deck construction pics from 2009 has full coils now
Radiatior on the back only way to go
imsohi
Post by imsohi »
Putting the truck back togeather
Front diff rebuild nice new shiney bits
Truck Almost ready for first cert Check
imsohi
Post by imsohi »
Will post some more pics tomorrow night
KIWI_TERRANO
Post by KIWI_TERRANO »
This was on trademe for awhile at one stage.....?
imsohi
Post by imsohi »
yea was then i decided to coil and supercharge it
KZN185
Post by KZN185 »
hey mate, sam here from last weekend (with the shiney red hilux) what were the results of the ramp test??? Cheers!
imsohi
Post by imsohi »
you or me :D i was 3rd and you were towards the rear of the list :roll: update will be posted on the website when i get a chance.
KZN185
Post by KZN185 »
imsohi wrote:you or me :D i was 3rd and you were towards the rear of the list :roll: update will be posted on the website when i get a chance.
oh well, gave it a go! my truck is 25k less than yours so not unhappy!
mercutio
Post by mercutio »
Glad to see i'm not the only one with a long build time :oops: :oops:
my 4wd is not a truck
imsohi
Post by imsohi »
mercutio wrote:Glad to see i'm not the only one with a long build time :oops: :oops:
:D its been a long time building but have had alot of fun in it tho along the way. :lol:
imsohi
Post by imsohi »
oh well, gave it a go! my truck is 25k less than yours so not unhappy![/quote]
I went over some older ramp tests and you truck was the same as mine back then, and ramp test arent always the best placing of well preforming trucks. i was impressed with you truck it loks the part and some exelent engerneering on the rear hook. Hope to see you out and about in the future.
imsohi
Post by imsohi »
2010 passed 1st cert brought some simexs and started breaking things :lol:
Brought off mike holmes only had about 1/2 tread
imsohi
Post by imsohi »
Paint job and external cage mid 2010
Pj_Marsh
Post by Pj_Marsh »
sweet lux
imsohi
Post by imsohi »
Also had setup a pto winch from the manual box for the 2010 thermal thunder in hamner, which when now i look back on it was a bit micky mouse :oops: the rear drive shaft from the r150 transferbox ran into another transfer box from a r150 that was flipped backwards the flange that would have gone to the front now went to the rear diff and the input shaft was the pto output which went to the winch. See what i mean :lol: it worked well but was slow unless dead winching.
3VILC
Post by 3VILC »
Nice truck.. I almost had to go check make sure you hadnt pinched the deck off mine :lol: very very similar design. I eventually want to extend mine to a cage like yours
imsohi
Post by imsohi »
We did the thermal thunder winch challence 2010 had a bit of a crap run, somehow managed to wrap the winch rope round the front drive shaft, oh it is rear mounted, then smashed a front cv learning about lockers and when to have them in and out the lost all compressed air wich put us out for the day ended up 7th from 8. First vid is of the compitition 2nd has my comp rig thanks of simon 4wd TV.
http://www.4x4earth.com.au/watch-4wdtv/?e=259
http://www.4x4earth.com.au/watch-4wdtv/?e=264
imsohi
Post by imsohi »
3VILC wrote:Nice truck.. I almost had to go check make sure you hadnt pinched the deck off mine :lol: very very similar design. I eventually want to extend mine to a cage like yours
Thanks, looking at mabey rebuilding mine wider to suit my new rear diff :roll: More to come.
imsohi
Post by imsohi »
After the thermal thunder the truck was looking a bit sad so thought i would take it off the road and give it a spruce up. then the misses kicked up a stink and wanted her vehicle finished was a year and a half in to the build. Needless to say hilux was on the back burner.
087-randoms 035.JPG (27.46 KiB) Viewed 12974 times
Tow Vehicle
Tow Vehicle
imsohi
Post by imsohi »
In the time i was building the surf i thought about what i wanted from my hilux it was the same time we were orginasing the top of the south winch challenge. I wanted a winch comp truck with coil springs so i whacked some radius arms on the rear diff and some std 80 series cruiser springs. this turned out to be an idea that would get changed once again.
imsohi
Post by imsohi »
After having a catch up with Jim (DA RAM) and numerous talks with Craig Craigs 4WD about suspension setups i decided that a 4link with panhard for the front was the best option. After laying under the truck imagining, planing and a little measuring i drew some plans of where my arms should go, then i checked and changed things so they wouldnt hit. finally i got out with the grinder and plasmer.
imsohi
Post by imsohi »
beefing up the front diff all mounts tacked then welded. design may have been copied from DA RAM!!!!!!!! Why change some thing thats looks like it will work :lol:. Springs are std 80series landcruiser.
imsohi
Post by imsohi »
Doubble shocks and hydraulic bumpstop settup not as easy as it looks lots of ups and downs then a tack then a cut retack ect ect seems to be all good now cant wait to test it in anger.
rokhound
Post by rokhound »
Nice bit of kit fella. 8) 8)
DA RAM
Post by DA RAM »
looking good :wink: i may need to pull finger :lol:
2015 JK Rubicon
