Vehicle lifts/Authority card
All aspects of safety with 4wds from proper mounting of tow hooks to recovery situations.
Bulletproof
Post by Bulletproof »
I have had a reply from LVVTA and soon there will be a discussion document on vehicle lifts by going to their Web site.
This is a copy of their Email
Hi Richard
First, please accept my apologies for the delayed response.
You are correct – there are some changes in the pipeline which will require a four wheel drive vehicle to have an authority card (or similar) if the owner wishes to modify the suspension/body lift beyond what would be considered reasonable levels.
This means that mildly lifted or raised vehicles will not be affected – these will continue to be LVV Certified as they are presently. Any changes will only affect vehicles with a large lift.
At this stage of the consultation period, we have been working closely with the NZFWDA – they are a national organisation, and are also an LVVTA member organisation, and so this is the ideal platform for ‘sounding out’ these changes. I would expect that this organisation would have similar ideals and expectations as the various other 4WD organisations around the country – you are welcome to make contact with them at any stage through their website - http://www.nzfwda.org.nz/
We do realise that there is likely to be a lack of understanding, where enthusiasts and members of organisations other than NZFWDA don’t properly understand what’s going on, why, or who it will affect. As a way to help those to understand these changes, we will be soon releasing a discussion document which will be available from our website.
I hope this helps
Regards
Justin Hansen
Technical Officer
Cheers Richard
Never say die, up man and try
redz driver
Re: Vehicle lifts/Authority card
Post by redz driver »
Excellant keep us posted aye
Real men drive swb leaf spring trucks
Kezza
Post by Kezza »
Great, that's what I was looking for. By the sound of things it's still gonna be sweet for people to do the 2" body lifts
no, body lifts need a cert, suspension of 2'' is fine
tallsam66
Post by tallsam66 »
I dont think they have told you the whole story.
If there havent been any changes done yet then why as of 1 July 2012 can NZ4WD Assn be able to issue Authority Cards for "Compliance with applicable technical requirements specified within relevant LVV standards ,applying to New Zealand Four Wheel Drive Association members covering only those components and systems that do not comply with applicable requirements for general use on the road , and valid for a maximum period of 12 months only."
Bulletproof
tallsam66 wrote:I dont think they have told you the whole story.
I am only going to take what he said at face value. If you think he is not telling the whole story why not email him yourself. His name is on the email sent to me.
Cheers Richard
toysuzi
Post by toysuzi »
coxsy wrote:no, body lifts need a cert, suspension of 2'' is fine
were did you get 2" from?
rules as they are now
springs and shocks . all out of the virm
b) the vehicle requires unreasonable force to steer, or
c) the steering is unreasonably stiff, rough or light, or
d) the vehicle does not handle safely under normal
conditions of road use, eg the suspension is
excessively hard or soft, or there is excessive body
roll.
• the springs or shock absorbers are direct replacements, and
• replacement springs are contained within unmodified OE seats throughout full
suspension travel, and
• replacement springs are self-retaining in their seats at full extension, without the use of
non‑standard devices such as wire-ties, straps, or external spring locators, and
• replacement springs have not been heated or cut, and
• springs and spring seats are not height adjustable (unless OE), and
• replacement shock absorbers, including air-adjustable units, fit unmodified OE
mountings, and
• suspension maintains sufficient travel for safe operation when fully laden, and
• suspension components maintain sufficient clearance from unmodified bumpstops
• a minimum of 100 mm ground clearance (unladen and without driver) exists below any
part of the vehicle structure, or any steering, braking or suspension component2, and
• the normal relationship between front and rear suspension height is not unduly affected.
2 Does not include such items as exhaust pipes and
and body lifts
3. A modification affects the vehicle structure – including an object or fitting affixed after manufacture that is welded to the chassis, sub-frame, cross-member or body of a monocoque structure, and
a) is not excluded from the requirements for LVV specialist certification (Table 3-1-1), and
b) is missing proof of LVV specialist certification, ie:
i. the vehicle is not fitted with a valid low volume vehicle certification plate, or
ii. the operator is not able to produce a valid modification declaration or authority card.
toysuzi:(SJ413) 3Y E surf engnie, 6" coil kit (RRO). toy diffs (4.88 R&P) & toy hilux box and t-case.
ifs toy power steering, 6" Bushwacker fender flares (RRO). ect
oh sorry it here say :roll:
KotangKort
Post by KotangKort »
Huh? I thought you needed cert for a 2" suspension lift aswell, I read TOYSUZI post on rules but that just confused me.
Can anyone clarify?
slide
Post by slide »
KotangKort wrote:Huh? I thought you needed cert for a 2" suspension lift aswell, I read TOYSUZI post on rules but that just confused me.
Can anyone clarify?
Depends on how its done. Basically tho, if its done properly 2" will be fine.
Lvvta probably havn't told the whole story. But neither has NZFWDA if this is true.
No mention of this in VIRM as yet, so as yet this card would be worthless in regard to getting a WOF.
Shows there probably is more going on in background that we don't know of yet. And we will probably find it out soon....
wayfastwhitee
Post by wayfastwhitee »
I was under the assumption that it was based on total lift? I have a 3" suspension lift with 31" tyres and it doesn't mention the tyre size (it does mention rim size) on the cert card. So I thought that the cert was suspension + tyre height (and body lift if you have one).
Bulletproof
wayfastwhitee wrote:I was under the assumption that it was based on total lift? I have a 3" suspension lift with 31" tyres and it doesn't mention the tyre size (it does mention rim size) on the cert card. So I thought that the cert was suspension + tyre height (and body lift if you have one).
Body lift is not included on my cert plate.
On my plate the m/metres are under the bump stops
Cheers Richard
Bulletproof wrote:Body lift is not included on my cert plate.
Cheers Richard
did you body lift the whole truck or just the tray Richard?
Bulletproof
Cheers Richard
Hi Marty
My body has a 32mm lift and the tray 75mm
The plate says front 674 and rear 712mm which is under the bump stops
Cheers Richard
Bulletproof
I have sent LVVTA another Email asking when the discussion Document will be made public, so if I get a reply I will keep you informed.
Quote
Hi Justin
Thanks for your reply.
Have you got any idea on the time frame for the Discussion Document to be made public ?
Or would it be possible to be Emailed when it comes out ?
Thanks again
Richard
Cheers Richard
basics
Post by basics »
thanks richard, keep us all informed
99 pajero exceed 3.2
Bulletproof
basics wrote:thanks richard, keep us all informed
I have had a reply
Quote
Hi Richard
Unfortunately I can’t give you a date – this is something Tony Johnson will be working on.
I will pass on your email address for emailing the document, however it would be a good idea to keep an eye on the website as well.
Regards
Justin Hansen
Technical Officer
Cheers Richard
tallsam66
Post by tallsam66 »
Tony Johnson is the twat at head of LVVTA
I have had a reply
Quote
Hi Richard
Regards
Justin Hansen
Technical Officer
Cheers Richard
mudlva
Post by mudlva »
[quote="tallsam66"]Tony Johnson is the twat at head of LVVTA
Not wanting to get into a war of words here...
And this info was given at the NZFWDA AGM that was held in Dunedin this May by Tony him self, I am unable to quote word perfect but it will be as accurate as possible.
Tony Johnson was a quest speaker and this is part of what he discussed
When the government was looking at banning all forms of modifications and any vehicle that was not built by a vehicle manufacturing company, he approached the authorities and started the process of developing a stand alone organisation who would work with the authorities on behalf what was then a small group of motor enthusiastic so that they were able to modify their vehicle to some from of safe standard that would appease that W.o.F. inspectors who were complaining that they were having to W.o.F vehicles that they deemed unsafe but there was no system to support or back up their decisions.
Tony was responsible for getting the LVVTA off the ground and with the assistance of many people (Peter Vahry was very proactive in ensuring that 4x4 was included) there is now 20 odd years later a draft of rules and guidelines for enthusiasts to modify their vehicles to.
The LVVTA is an extraordinary organisation that is completely unique to New Zealand only and as such many enthusiasts from other countries look at us with a twinge of jealously. Here we are able to scratch build a vehicle and get it on the road with a minimum of bureaucracy. We are able to get a perfectly nice vehicle that the manufacture has spent tens of millions of dollars creating and at a fee of less than one grand completely modify it to some thing well beyond what any tech ever thought possible. Not many countries would allow this.
Now I don’t know Tony personally but I do think that calling him names wether its personal or not, properly isn’t in anybodies best interest
Rohan Hooker
Northern Zone PRO
LOLYF
Post by LOLYF »
tallsam66 wrote:Tony Johnson is the twat at head of LVVTA
Tony Johnson IS the head of LVVTA, The guy that fights for OUR rights to modify OUR vehicles. :roll:
tomsoffroad
Flopsie
Post by tomsoffroad »
That must be a coincidence Richard. The height measurement is from the centre of the hub to the guard lip. :wink:
Nigel Bannan
Post by Nigel Bannan »
So true Tom.
Nigel Bannan
Secetary/Treaesuer
Combined 4Wd Clubs Inc
Ralfie
Post by Ralfie »
Return to “4wd Safety”
