NISSAN SAFARI LIFT?
NISSAN SAFARI LIFT?
does anyone know if king springs do a legit 7 inch lift for a long wheel base safa?
seen some on trademe wondered if its right or not?
Re: NISSAN SAFARI LIFT?
why a 7 inch lift ,
You will have to fit oxygen bottles as well as the air is quite thin up that high, why do you want to go so high?
- Suza
dont forget the drop down ladder
faaark, 7 inches
you trying to make up for something
- crazyclark31
thats a funny way over shortening the wheel base.
The blimin control arms would be near vertical.
crazyclark31 wrote:thats a funny way over shortening the wheel base.![]()
Longer superior arms, problem solved
i just seen them on trademe i didnt think they would make them that high... and they were cheap
7 inches is pretty high and would need alot of modifications, I have a shorty with a 3inch lift and that is plenty high enough, even 3 inchs seems too high.
What sort of driving are you going to do?
3'' on a swb is equal to a 6 '' on a lwb
have 4" front 5" rear lwb lift in my shorty 37s fit no body lift
WARNING:
taz01 where did you get yours from?? and what other work do you have to do to run a lift like that?
Might be better if you paid up accounts owing before you start another......
coxsy wrote:3'' on a swb is equal to a 6 '' on a lwb
How does that work?
yea na its got me effed... some people on here are high it think but who knows
Nis-man wrote:coxsy wrote:3'' on a swb is equal to a 6 '' on a lwb
How does that work?
It's in regards to Ramp Over Angle, Longer wheel base needs to be lifted higher to have the same ROA as a Short wheel base
So is that the only thing it affects?
Smurf wrote:Nis-man wrote:coxsy wrote:3'' on a swb is equal to a 6 '' on a lwb
How does that work?
Nis-man wrote:So is that the only thing it affects?
Not sure what you are asking?
- curly12
orange wrote:taz01 where did you get yours from?? and what other work do you have to do to run a lift like that?
ZFrom out of my POS
7 inches pffft
you can go higher
that is what i am talking about!!!
found it out a thompsons track me 3'' lift 34'' simexs beside a lwb saf 6'' lift 35 tyres, we could talk window to window at same level
How does that work?
Other way round, e.g. 3" on LWB equals 4" maybe 4.5" lift on a SWB depending on truck.
Does it come down to what brand of springs you use, I can not see why there should be a difference in ride heights between swb and lwb unless some has used swb spring in a lwb or vice versa?
isnt it because the springs are how would you say it tougher because of the weight of the long wheel base..
- crazyclark31
yes but they are made to suit that vehciles weight so a 3in kit for a shorty should give the same lift as a lwb 3in kit in a lwb.
Different brands give different lifts and the age and spring rates all affect the actual lit height
If only you could do a spring lift without worrying about all your other factory components.
This is where I started looking for mine (Note: SWB):
http://www.suspensionstuff.com.au/shop/ ... ts_id=1345
In the end your upwards of $4000 AUD for components alone.
