WANTED!! simple air box 4 hilux
rudrty
Post by rudrty »
as ive said in other posts im turboing my hilux engine (3L)
my airbox is ok but i little worse for wear an realy quite hard to make water tight now (dont ask) im looking for somthing small an simple to seel so that when i get my turbo on finaly im not having to constantly wory if my intake is going to leek. so does any one have sumthing lying round in their party bins?? if your anything like me ul have a few random bits. :?
Moriarty
Re: WANTED!! simple air box 4 hilux
Post by Moriarty »
rudrty wrote:as ive said in other posts im turboing my hilux engine (3L)
Had the same prob, not so much as getting a seal, but factory fitting is mounted far too low. my solution....
The vacant space left bottom of pic is the site of the factory air box.
rudrty
Post by rudrty »
yeah good idea but ive got a snorkel so i have to have an actual airbox i just dont like the factory one
Moriarty
Post by Moriarty »
Been wondering about that, When the twuck is out of warrantee, and suspect if the dealers saw this mod, that would be NOW!! lol I will put a schnorrekill in too.
Would it be possible to put the filter high up in the snorkill tube? Or would that be too much weight up high and lead to failure of the tube.
Or tip a light truck over.....
I am gonna put a compressor in the huge vacant space the airbox used to occupy. So I need to really think about where to filter incoming air.
rudrty
Post by rudrty »
i had my air filtered at the top of the snorkel, brob what ill go back to doing when ive got my turbo.
Image[/list]
H2OLOVA
Post by H2OLOVA »
I used to run a pod type filter on the top of the snorkle on my series 2 landrover, problems i had was getting wet, which effectively choked the engine a bit and getting smacked around by trees etc. If you can i'd be getting/keeping an airbox that you can fit an airfilter into, that way its tucked away safely. You can buy unifilters which are a foam type filter that you can wash out, reoil and reuse when they get wet or dirty.
