Hi there
Wheres the best place to get suspension balljoints and steering tie rods for these trucks? I'm in Wellington but would also order online if price was better.
Also, looking for the cup-washers for the tension arms (compression rod) bushings - I have new bushings and sleeves, but need washers
Also looking for the clutch slave cylinder boot where it bolts to the trans bellhousing
Anybody have any ideas??
Parts supplier WD21 Balljoints, TREs etc
Re: Parts supplier WD21 Balljoints, TREs etc
Ball joints and TRE's from BNT, but TRE's they are cheap crap that only last a few weeks before getting flogged out
Washers from any wrecker that has a D21.
Slave cylinder boot.....who needs it, they do f*** all.
You can get complete new cylinder for real cheap from BNT as well
Cheers, yeah I guess 33s and torsion twist will spit the TREs pretty quick. Is there a supplier of moog tie rods in NZ??
lax2wlg wrote:looking for the cup-washers for the tension arms (compression rod) bushings - I have new bushings and sleeves, but need washers
Autolign have them... here is the part number http://www.nolathane.com.au/product_detail.php?part_number=42933
sibainmud wrote:Ball joints and TRE's from BNT, but TRE's they are cheap crap that only last a few weeks before getting flogged out
From Bnt (and/or Autolign; same company
I also believe they are going to have the moog (federal mogul) brand shortly-ish.
DEATH_INC wrote:I also believe they are going to have the moog (federal mogul) brand shortly-ish.
Let us all know if you hear more about this please. I was looking at getting some from the US but the freight is a killer there.
Ph 0212078472
Ph 0212078472
lax2wlg wrote:Also looking for the clutch slave cylinder boot where it bolts to the trans bellhousing
Do you mean rubber boot on clutch cylinder, or rubber boot on clutch fork to stop water etc getting inside bellhousing?
Cochram nissan do some good prices (and some not so good
