viscous fan
waypa
viscous fan
Post by waypa »
How does one test a viscous fan.My fan has some resistance when cold but does not get any stiffer when hot. I thought the fan should stiffen up as it gets hotter, any ideas.
tweake
Re: viscous fan
Post by tweake »
not to sure what type mitsi use but if its the same style as toyota the fan should spin a little bit when hot. ie give it a spin and it should do about 1/2 a turn or so. if it keeps spinning then its needs the silicone oil replacing.
pjb
Re: viscous fan
Post by pjb »
Pretty sure the Mitsi ones work the same as the Toyota ones.
They are pretty hard to bench test as they need the centrifugal action of them spinning to distribute the fluid inside the device.
Details here: http://au.burton.com/on/demandware.store/Sites-Burton_AU-Site/default/Product-Show?pid=252175&dwvar_252175_variationColor=252175100
So, as far as I can see, there's no way to (correctly) measure the behaviour of the fan while it's stopped.
94 Pajero SWB, 3.5 V6
Re: viscous fan
split wayne fan hub yesterday
cleaned old oil out, refilled side in photo 1
reassemble seems to be good
Return to “Mitsubishi”
