Your best modification....
Whats the single best mod yourve done to your truck?
mine might sound a bit strange but it would have to be putting surf seats in my hilux. they would have to be 10 million times more comfortable than the standard buggars!!
4wdnuts wrote:looks good reece. you gona be driving that beast from the back seat?
Back seat ??
na gona sort it so the original trans lever changes box 2 and it will be set up with a couple of side levers from the trans (using push pull levers) that work 2-4WD and Hi-Low
Oh and becouse I've moved the motor as far forward as I can (radiators going in the back
Cheers Reece
- niblik
- Sausage Shack
Re: Your best modification....
4wdnuts wrote:Whats the single best mod yourve done to your truck? !
should i start something? should i? oh...... ok...
i bought a toyota..
- mroffroader
- Moriarty
[quote="Jerry"]loosing 12 inches......!!!!! I hope there is something left........
I keep getting these emails for some pills if you want the 12 inches back and need the info...
quote]
AHHHH at LAST!! someone else who admits to these pernicious emails.
What I really wanta know, Jerry, do the pills work? academic interest only, you understand!!!
quote]
- PuddleJumper
- mroffroader
