Recovery points.
All aspects of safety with 4wds from proper mounting of tow hooks to recovery situations.
MikeL200
Gadget Guy
Recovery points.
Post by MikeL200 »
http://www.4wdhandbook.com/rmp/blog/myth-rated-4WD-recovery-points
Thoughts?
I can see what he is thinking about.
Mike
1989 LandCruiser MWD BJ74 13BT
33 Deserthawk XMT.
If guns kill people, then,
Spoons make people fat,
Pencils mis-spell words,
and Cars make people drive drunk.
021 666812
Dirtydog
Re: Recovery points.
Post by Dirtydog »
can definitely see what hes talking about, and he has some very valid points.
i wonder if not using rated recovery points on vehicles will be something the insurance company will fight over. if so theres something to back your answer.....
tweake
Post by tweake »
yes/no
while they are not really "rated" the whole idea of using rated points is to get everyone fitted with similar points mounted in a similar way so they are predicable in use.
that way other people do not have to guess on how much force your points will handle.
klompy
Post by klompy »
My understanding is that 10000lb rated hook will straighten and let the strop come free when overloaded not rip of or break free becoming a projectile.
DaveM
Post by DaveM »
klompy wrote:My understanding is that 10000lb rated hook will straighten and let the strop come free when overloaded not rip of or break free becoming a projectile.
Yip, my understanding too (providing they are mounting correctly). This is the reason I use them
Moriarty
Post by Moriarty »
Is it, Mike, when we talk of "Rated recovery Points" that we are referring. not to the mounting of a hook, but the hook, itself?
Hence, you MUST have a rated HOOK as your recovery point, NOT a factory fitted towing eye, tiedown point?
This is how it was pointed out to me by the guys up in the Waikato, who had me in their care during mu initial training as a new 4WDriver.
007
Post by 007 »
That is my understanding too. I gess a rated hook is only as strong as it is mounted.
On that point here is ccvc minimum mounting requirements, if anybody doesn't know how to mount there hooks.
http://www.ccvc.org.nz/index.php/ccvc/c ... 050803.pdf
ford ranger wildtract and sj.
I follow those designs, no problem with hooks in years
yeah dosent really matter how rated a hook is if the mount comes off with it :shock: :x
tweake
Post by tweake »
been seeing a few problems on forums with lighter 4x4's ie 3mm chassis.
captive nuts being ripped out, nuts being pulled through the chassis. lack of load spreaders or backing plates.
also D's are favored (and they are "rated") which means a shackle is required, which adds to the missiles weight.
Bush Chef
Post by Bush Chef »
http://www.youtube.com/watch?v=-Ire31FrEAI&feature=related
this guy puts his snatch strap inside his receiver hitch and then puts the locking pin through
looks like a plug for ARB gear
thoughts on this method ?
tweake
Post by tweake »
bending the pin and not being able to get it back out.
also i would be concerned about strap being pulled against the edge of the hitch.
Return to “4wd Safety”
