5l turbo kit
mrhwilson
5l turbo kit
Post by mrhwilson »
just wondering if anyone knows of a place that sells turbo kits to fit the 5L. i got a quote from someone and they said 3500 just for the kit.
Re: 5l turbo kit
bulletproofs hilux thread might be worth a look ... he supercharged his
mrhwilson
Re: 5l turbo kit
Post by mrhwilson »
yea id rather a intercooled turbo system if it possiblle but cheers
Smurf
Re: 5l turbo kit
Post by Smurf »
Turbo and manifold from 2lte and exhaust mod and sump mod, cost you a few hundred all up
mrhwilson
Re: 5l turbo kit
Post by mrhwilson »
anyone got any ideas of a intercolled system that wouldbolt straight on tho?
sr5dan
Re: 5l turbo kit
Post by sr5dan »
was wondering the same thing ive got 1kz-te hilux and was told top mount intercooler of prado will bolt straight on cheeper than custom
crazyclark31
Re: 5l turbo kit
Post by crazyclark31 »
the 2lt turbo setup is as close to bolt on as you can get without spending big $$$$$. The manifolds bolt straight on. You only need to change the exhuast at the turbo and put a return pipe into the sump. and tee in an oil feed
as your truck is not a intercooled model there will be a bit of dicking around to make it fit. you've either gota make up pipe work for a front mount or cut great hole in youre bonnet for top mount. very unlikly you'll get something that will bolt straight on
KIWI_TERRANO
Re: 5l turbo kit
Post by KIWI_TERRANO »
Hey mate i got 03 lux with a 5l im turboing
I got a 2lte manifold and turbo a 2lt intake manifold and a 2lt oil cooler( bit oilfilter screws onto for oil feed) and custom drain into sump im also intercooling it front mount as its easier and heaps of room. Using a 4m40 fuel pump to tune it better and lose efi pump. All up its cheaper than a kit from oz and kits dont have intercoolers
mrhwilson
Re: 5l turbo kit
Post by mrhwilson »
cheers for that. any ideas on the best place to get it done in chch?
hammd
Stropper
Re: 5l turbo kit
Post by hammd »
previous 5l on 14psi with our set up 110kw at rears approx 4g inc full 2.5inch exhaust
hammd
Stropper
Re: 5l turbo kit
Post by hammd »
sorry hp at wheels
rangimotors
Re: 5l turbo kit
Post by rangimotors »
mrhwilson wrote:cheers for that. any ideas on the best place to get it done in chch?
go and have a chat to kaipoi repowers Nathan will help you out.
