Leaking coolant?
crazydragon
Leaking coolant?
Post by crazydragon »
I'm honestly at my wits end here. I just spent $1k repairing the bushes, fitting new brakes and new tailpipe. This morning my truck is leaking coolant. Honestly I don't know what to do anymore, the problems are coming faster than I can get cash.
I'm not so sure what's going on but it's been leaking quite a bit of coolant. Possibly about 20ml since last night. I looked it up on google and to my despair everything seems to say it's a blown gasket.
How much am I looking at if I need to replace the gasket?
Henry
Re: Leaking coolant?
Post by Henry »
Hi
What is the truck?
What is the engine?
Where is the leak?
Was the engine hot ? Cooling down?
have you added coolant lately?
Are you using antifreeze?
Why are you saying head gasket?
crazydragon
Sorry forgot to mention the details.
It's a 1994 Toyota Prado KZJ78. It has the 1-KZ TE engine in it.
The leak is somewhere below the glove box, or in between the driver and passenger seat. It leaks on to the ground.
It's leaking yesterday night where it was cool. It's also leaking after I drove it today.
Yup I just added the red Toyota coolant about 10 days ago.
I'm not sure if it's the head gasket or what, but I had a look up on google and everything seem to point towards blown head.
Henry
Post by Henry »
You do realize the air conditioning drain runs out there?
crazydragon
But the leaked liquid is red in colour. That's why I thought it was the coolant.
Henry
Post by Henry »
So going back to the Cracked head thing.
Are you loosing coolant?
is there oil in the coolant?
Is there water in the oil?
However you really need to find the source of the leak. underneath with a torch is the place you need to be...
It could be a heater hose as well...
crazydragon
I'm still waiting for the engine to cool down before opening the radiator. But there was a decrease in coolant from the overflow tank.
I'm not so sure how to check if there's oil in the coolant or water in the oil.
I had a look underneath just now but I'm not even sure what am I looking for. Most of the pipes seem to be wet, so I really don't know which one is leaking. And it's stopped leaking now making things even harder to check.
crazydragon
Just checked the radiator, yeah the coolant has gone down quite a bit.
Henry
Post by Henry »
So do it the other way. Wait till it is dry and refill radiator and start looking again.
badnuz
Post by badnuz »
if its on the ground its not in the engine where it shouldnt be (ie in the oil) then my thoughts is a heater hose somewhere.....
crazydragon
badnuz you reckon it's not the head? If it's a blown head or cracked head, will coolant leak to the ground or will it go straight into the engine?
Will the heater hose be cheap to fix?
sibainmud
Post by sibainmud »
I'm thinking heater hose or the heater coil if the coolant is ending up on the floor pan. Correct me if I'm wrong, do those prados have a rear heater? Could be the tubes/hoses back to that heater also. If it was the engine, then coolant would be on the groung under enginebay.
badnuz
Post by badnuz »
crazydragon wrote:badnuz you reckon it's not the head? If it's a blown head or cracked head, will coolant leak to the ground or will it go straight into the engine?
a heater hose is a cheaper and eaiser place to start looking at.... :mrgreen: it could still be a head related issue but look to eliminate the easy less expensive stuff 1st 8)
crazydragon
How much am I looking at if I only want the heater hose replaced? I'll go talk to a mechanic tomorrow and see if they can fix it. Just roughly how much? Will it be over $300?
badnuz
Post by badnuz »
that will depend entirely on which heater hose and where it is! 9and assuming its not the heater core leaking... are the inside carpets wet?
kbushnz
Post by kbushnz »
The heater hoses are right at the top center of fire wall, right behind the head.
The hoses there could be leaking...
Also there is a hose and pipe which run under the truck to the heater for the rear passengers.. Its in the console between front drivers seat and passenger...
I would give the truck a good clean let it dry and then go for a drive on dusty road and look for the wet patch... :mrgreen:
kbushnz
Post by kbushnz »
Hey crazydragon can you update your profile and put in your location.
A local ORE member might be able to help you and take a look etc etc...
crazydragon
Calvin you were right again. Turns out the pipe going into the heater from engine bay was leaking. Had it fixed and did a pressure test so everything is okay for now. Midas also apologized and had my tailpipe replaced.
Truth be told I'm in a dilemma right now. I really liked this truck and I've spent quite a bit of money so far fixing a lot of stuff. By a small part of me want to sell it right now while everything's still holding together. Then again if I sell it, I will need to look for another second hand car which may have as many problems as my current truck.
Too bad I'm leaving Auckland to Palmy for studies tomorrow. But one day I would like to meet some of you guys. Especially Calvin, the KZJ78 expert.
Thanks everyone for all your input. Really appreciate all the help and advice.
kbushnz
Post by kbushnz »
crazydragon wrote:Too bad I'm leaving Auckland to Palmy for studies tomorrow. But one day I would like to meet some of you guys. Especially Calvin, the KZJ78 expert.
No problems there, Enjoy Palmy.... Ginzu8 hangs out down there and has a KZJ78 also....
As for the expert......nah just like tinkering and listening / reading what others have had issues with....Then its just a matter of remembering.... :lol:
Ginzu8
Post by Ginzu8 »
You r the guru when it comes to kzj78 Calvin. Crazydragon, keep the truck. A mate of mine also have one in palmy.
crazydragon
Managed to drive down to Palmy. Stopped every 2 hours to let the engine rest for 30 mins. Not sure if that works but I was being paranoid. So far so good. Nothing's leaking yet. But when start up it blows a lot a lot of smoke for a good 10 seconds before settling down to no smoke. Any idea what's causing this? It's only when I start it. Happens every time now since 5 days ago..
kbushnz
Post by kbushnz »
I think if you were going to have issues they would have shown themselves in the first 10 to 20 mins....
Apart from a sudden failure...
As for the smoke... what colour is it... White, black, grey...
Smell oily or hot water or diesel fume smell.
has it just started smoking or have you only just noticed it?, my 78 coughs a bit of smoke on startup (and when on a hill) my 90 series the the later 1kz did it as well.
If you are in palmy now go and see euan (badnuz) at ARB hq (autokraft) .. hes usually got free stuff .... coffee, stickers ... jackets :lol:
crazydragon
I know it's always had a little smoke during start up but the last 5 days it suddenly had a lot of smoke and would always continue for around 5-10 seconds. It's white smoke, not sure how to describe the smell though. But 2 out of 5 times it would start normally without smoke blowing.
Thanks Jerry I'll definitely visit his shop one day.
kbushnz
Post by kbushnz »
It could be unburnt fuel....
With this cold spell you may want to turn the key on twice.....Before kicking over the starter..
To make the glow plugs work a little longer...
crazydragon
If there's something wrong with the head gasket, what will a pressure test of the cooling system/radiator show? Apparently the guys at Midas did a pressure test for free and said that nothing's leaking and everything seems fine.
The blowing smoke thing happened even after I droved it for 2 hours. Then again I did take a 30 mins break so I'm not sure if the engine has cooled down that much. I will try your method for this whole week Calvin and see if that still happens.
kbushnz
Post by kbushnz »
When my head cracked it used to puff white smoke / steam for a few seconds after a hot start only... Ran like a bag of bolts for a few seconds while it cleared its throat like a petrol car with a miss...
Then with the radiator cap off (let it cool off a bit so you don't get splashed with hot coolant) with engine running it would puff out bubbles of diesel fumes out the radiator.... 8)
However you could have a leaky injector which is putting fuel into engine while at rest?
What say you diesel guru's
crazydragon
Just checked the radiator and overflow tank. Looked dried up but 2 days ago it was still quite full! No signs of coolant leaking on the floor. This doesn't look good at all. I didn't drive it since 2 days ago when I checked. Any idea where did the coolant went?
Ginzu8
Post by Ginzu8 »
Hey mate. go to Tim Buys in Palmy North if you need work done. He can be an ass at times but generally him and his guys knows what they doing.. I guess if you dont see any leaks on the ground it would mean its going into the engine.. :cry:
I would top the radiator back up and leave the car there for half a day . and if the radiator is dry or has gone down there has to be a leak but if the level stays the same i think its bad news
crazydragon
So the coolant will only leak into the gasket when I drive it? What will pressure test on the radiator say if there's a cracked head?
Return to “Toyota”
