I have a screaming 8
Which would you recommend
Sadam_Husain wrote:the silverstones were always an undersized tah, they have got new moulds bringing the size up now but from what I've been told you have to be carefull what you order coz theres still old undersized stock floating around
as far a comparison between silverstone and simex the silverstones have bigger voids between both the centre blocks and outside blocks and are a softer compound
Big wrote:.. as price for simexs is main reason not get them but if it means not tearing lugs then I'll get them.. see what I mean..I dont really want to spend 400 each only to fk them .. rather spend more and have them last..
Sadam_Husain wrote:Big wrote:.. as price for simexs is main reason not get them but if it means not tearing lugs then I'll get them.. see what I mean..I dont really want to spend 400 each only to fk them .. rather spend more and have them last..
when did you last price silverstones there not 400 bucks anymore there almost the price of simexes![]()
007 wrote:From what I have seen, I think both are a good off road tire, of the same design.
Sizing is another consideration, especially if you want the 36'sX12.5 which is an advantage of the Simex and size does matter.
But the larger lug spacings of the silverstone equals more grip in a comparison size, which is important if you are restricted to the smaller tire sizes.
Silverstones should also be easier to bag with the the softer compound.
It is a tough comparison as both are so similar.
You will also need to consider the weight of your rig and how often you plan on replacing them.
If you 4wd in Queenstown the rocky terrain may also be a consideration for you
They are both popular tires. I have never run silverstones but find the simexes (36X12.5) great in the goo.
Big wrote:Well after getting the silverstones.. im totally happy with how they rock.. I just have to learn how to use them![]()
I have noticed a move towards the silverstones but Im not sure weather its because of price of performance..and I have noticed the top guys starting to use them and cant fault them really..compared to the simex..
I had 1 run on them and can say they are awesome but cant really compare to anything else as I havnt had anything else.. if that makes sence..lol time will tell.. cheers
juz wrote:They dont wear that quick, I got my 35" Silverstones off kbjj with I think 12mm tread? cant quite remember, but I use my truck to run around town a bit and weekend 4wd trips and dont change them. Ive probably done 8000km on them and they wouldnt be down to 10mm. On a heavier Vehicle, Safari 80series etc I imagine road kms would be alot less though.
