fj40 extended rear shackles wanted
After some extended rear shackles for my 82 fj40, ideally want them around 120mm-130mm from centre of pin to centre of pin
Re: fj40 extended rear shackles wanted
have thought about it, what would I use for the pins?? bolts??
- niblik
- Sausage Shack
yeah man.. for sure.. you can even make em greaseable.. easy enough done..
thanks might look into it
