So, the last week has been spent in the winterless north. The original plan of just popping the coby in and getting a bar on changed a little.
The draglink came off and another tube sleeved and stitched over it, and we also partially flipped the pitman arm to lift the draglink up outa the way... no more being the first thing to get hit.
Then the radiator came out......
which left some shortening to do in the front....
Guards to shorten as well as the chassis......
And a bar to start fabbing.....
Then, I discarded the snork idea and went for a pod and a hole in the firewall....
The twin fans on the back are operated off the hi-beam switch. We established (when we had one fan plumbed in) that when you leave the vehicle, and the lights/fans are on, the buzzer goes.. all good, cant forget to turn the fans off then.
The back of the bonnet has been cut about 3 inches too, with the intent of stitching it back onto the hinges. A couple of pins and R clips will secure it at the front, the guards will be folded to suit at the front (as in one of the pics, but still needs another 50mm yet to for the bar to clear), and the bar should hide the actual detail of the folding. So it essentially will look like a bobbed front and back Disco still. It didnt help the tidiness of it all though when we accidentally swung a ex200's bucket into the front left guard when it got away from us hanging off the gantry.
guards will likely trim back to here:
and the finish something along these lines???
No, the track bar isnt going to be moved to coincide with the movement of the draglink
Yes, there will be some kind of barrier between the fans and the dicky-seat, more than likely something simple like a coreflute sign
