Longfield Supersets for LJ7x and KZJ7x Series
Following on from my 70 Series axle lengths thread http://www.offroadexpress.co.nz/Forums/viewtopic.php?f=22&t=31346
How much interest would there be in me getting some Longfield Supersets to suit. Just need to remember that you also need to either run their hub gears or drive flanges. The drive flanges make the hub assembly much stronger as they have 6 drive pins extra to the 6 taper lock bolts.
Note that the pre 1990 FJ70 are the same as FJ40.
Now sorted see following post.
Tim
Tim
Re: Longfield Supersets for LJ7x and KZJ7x Series
Hi,
Following on from above I ordered and have now got custom length axles from Longfield to suit the LJ7x and KZJ7x. The earlier model ones should be a direct fit as the oil seal diameter (33mm) should be the same as Hilux and earlier FJ Cruisers, for the later model ones the oil seal ID is 35mm, so the oil seal wil need to be changed to suit the longfield axles, the OD of both seals is 50mm. The larger seals are the same as the 80 Series seals.
For the earlier ones that don't need seals Cost is $1350 plus post which is about $50.
For the later ones that need different seal Cost is $1350 plus post which is about $50.
You will just need to get early model seals.
The toyota seal no is 90310-35010.
For the longfield warranty need to run Hub Gears ($225) or Drive Flanges ($300)
PM me if interested
Tim
PM me if interested
Tim
Bump.
See first post
PM me if interested
Tim
See first post
PM me if interested
Tim
Bump.
See first post
PM me if interested
Tim
See first post
PM me if interested
Tim
Bump.
See Second post
PM me if interested
Tim
See Second post
PM me if interested
Tim
Bump.
See Second post
PM me if interested
Tim
See Second post
PM me if interested
Tim
Bump.
See Second post
PM me if interested
Tim
See Second post
PM me if interested
Tim
Hey tim will be looking at getting a set some stage this year most likly with drive flanges i will let you know
Bump.
See Second post
PM me if interested
Tim
See Second post
PM me if interested
Tim
Bump.
See Second post
PM me if interested
Tim
See Second post
PM me if interested
Tim
Bump.
See Second post
PM me if interested
Tim
See Second post
PM me if interested
Tim
Bump.
See Second post
PM me if interested
Tim
See Second post
PM me if interested
Tim
Bump.
See Second post
PM me if interested
Tim
See Second post
PM me if interested
Tim
Bump.
See Second post
PM me if interested
Tim
See Second post
PM me if interested
Tim
Bump.
See Second post
PM me if interested
Tim
See Second post
PM me if interested
Tim
Bump.
See Second post
PM me if interested
Tim
See Second post
PM me if interested
Tim
Bump.
See Second post
PM me if interested
Tim
See Second post
PM me if interested
Tim
Bump.
See Second post
PM me if interested
Tim
See Second post
PM me if interested
Tim
Bump.
See Second post
PM me if interested
Tim
See Second post
PM me if interested
Tim
Bump.
See Second post
PM me if interested
Tim
1 Left
See Second post
PM me if interested
Tim
1 Left
Bump.
See Second post
PM me if interested
Tim
1 Left
See Second post
PM me if interested
Tim
1 Left
GOT SOME MORE
Bump.
See Second post
PM me if interested
Tim
Bump.
See Second post
PM me if interested
Tim
You still got some of these ?
Hi Trevor,
Yes still got some.
Tim
Yes still got some.
Tim
Hi Tim,
You got any Nitro gears at the moment, heard you may?
Got some 4.88's in a few days, what ratio are you after.
Tim
Tim
bloody 4.56... would need the fitting kit with flange etc too.
only 4.56 i have is a Yukon Hi Pinion
Tim
Tim
All Good Tim, they cheap enough to bring over, you got any tg solid pinion spacer kits?
