Ok so I have had to replace my old chassis as it was a gonna, I did't realise that I needed to get a cert on it after I got it all changed over, thought it was a case of filling out forms etc, so chose not to do any cert worthy mods.
However seeing that I need a cert now I may as well fit the body lift I have had laying around for a while. It's is only a small 1 inch lift.
So first of all will the standard bolts be fine? Secondly the diameter is 76mm with a 13mm hole in the middle, so do I just place them on top of the rubber mounts? or below them? If below them do they need some machining as the indents in the chassis are not big enough for them?
Thanks for asking my nooby questions.
Lincoln
