hilux axle questions
lilpigzuk
Tiger Balm
Post by lilpigzuk »
How interchangeable are brake callipers between beam axles ad IFS models?? Have some running gear without callipers.
If I do end up running these, what are the better ratio diffs for strength?? Not too fussed about ratio themselves.
Thanks
Rex
(I know SFA about Hilux's..... :oops: )
Clint
Post by Clint »
The later model 4.88's (out of the LJ71's :D )are allegedly the strongest 'hilux' diff around, or so I've been told anyway.
Clint
UZJ71 Landcruiser
KTM 640
Toyhatsu
Post by Toyhatsu »
Generally the higher the ratio the stronger the diff so a 4.3 ratio is stronger than a 5.1. I am told this is because the diff with the fewer amount of teeth on the same circumerance crown wheel therefore has broader teeth and so is stronger??
Also the 4 pinion diffs are stronger than the two pinion diffs. The diffs behind the six cylinder versions of the surf are stronger again with extra webbing on the sides to stiffen the third member over its length.
If you get one with an lsd get it tightened up because the standard ones suck!!!
http://home.4x4wire.com/erik/diffs/ - heaps of good info about yota diffs :D
rokhound
Post by rokhound »
100% correct (or should I just say agrree) on all count Toyhatsu :D
Toyhatsu
Post by Toyhatsu »
ta rokhound, happy to oblige
Return to “Toyota”
