So my surf has a 2" bodylift and 2" lift spring installed (shocks to suit also), problem is the front end is a little lower than the back (not even 1" but enough to annoy me) due to the torsion bars only being wound up to be almost level. Now i could just wind them up more but i've read/heard this can give little to no travel in front shocks and c.v's will be in for a lashing.
Question is will 1 of these ball joint spacer kits sort this problem???
http://www.trademe.co.nz/motors/car-par ... 403192.htm
I figure if that kit lifts the front 1" then it would level the truck out and i wouldn't have to wind the bars up to do it thus keeping the travel in the shocks, less strain on c.v's and brake lines etc.
Am i on to something here or nah?
