gq y60 safari pto lever n cable
this is the cable from pto drive to the in cab lever either 1 prefer both.....
taz01
Wtd: y60 safari pto lever n cable
WARNING:
Re: Wtd: y60 safari pto lever n cable
I don't have either but the cables are a standard 33C marine remote cable, go to your local marine workshop and get them to order you one if you can find what length you need ( they come in lengths from 1-30+ft ) and they will also be able to get the fitting to screw on the ends of the cable.
If you cant beat us Gingers, JOIN US!!
put a motor bike rubber cable cover on the lower slide point fill with grease stops crap filling cable and become unmoveable
