found some extra time today so made most of it and installed new panhard rod.
also started back on the sliders, the ones i started way back on page 8
will have two bolts on each 'U' bit. nuts will be welded on.
here's where i stuffed up, im a dumb ass.
i wanted to put three outriggers on but Ive welded on the the sway bay bracket, in the most suitable place for the third outrigger at the front.
i should cut off sway bar bracket and weld to 'U' bit and combined with outrigger. but that's in the bastard job section at mo, will ignore it for a few day see if it fixes itself.
