Right, been given a car from my mum which decided it was better off being a non runner
Its a 1990 mitsi galant
Engine is a 4g37, 1.8 non turbo, 195kms on the clock.
From what I was told it was driving then it just stopped
Now all it does is turn over then it fires once as in it sounds like it ignites 1 of each of the 4 cylinders then just keeps turning over.
Ive checked the compression, thanks to Sibainmud lending me the magic tool
It came back with :
1 - 135psi
2 - 140psi
3 - 125psi
4 - 115psi
Now those figures dont seem right too me I thought petrols are usually round 80-90psi?
I was reading something about these motors stretching cambelts and putting the timing so far out that they barely move under load, so I checked the cambelt to find that it has nicks and cuts in it and its about to let go
So to try counteract this problem I then advanced the timing all the way, then retarded the timing all the way to see if the timing was stopping it from running due to a dodgy cambelt.
It still did the exact same thing both ways it would just fire once then die again, so either the timing is WAY out and adjusting the dizzy does nothing or theres another problem which I cant figure out.
Any ideas?
Caleb
