urgent where to get mudflaps etc in chch
- jonossiksilvia
Long story short I need to fit mudflaps to the rear of my truck as requested by nzta due to a random audit check that overwrites cert man before the cert plate can be fitted wat would u recommend to use? Need something cheap and quick. Was thinking truck mudflap cut in half vertical but not sure where to buy over counter. Will explain the hassles ive been through once plate fitted. Thanks in advance
Re: urgent where to get mudflaps etc in chch
I got some at TWL. Was pretty cheap.
- jonossiksilvia
Where bouts is twl?
edit: sorry working off the phone at the moment
Last edited by jonossiksilvia on Thu Aug 09, 2012 5:39 pm, edited 4 times in total.
Branston St
- rangimotors
- jonossiksilvia
Thanks will call them now
if you wana red neck fix, use an old rubber floor mat cut in half.
cheap and easy
cheap and easy
99 pajero exceed 3.2
If all else fails Repco or Super Cheap normaly have them. Can easily modify them to suit your truck.
- jonossiksilvia
got a rubber mudflap from twl 24"x36" for $52 retail
cheers all for help. look out for the cert story soon
