WTB ::Ignition and door locks for Safari
Looking for ignition with key and matching door locks for a Y60 safari please
- williamhamilton
Re: WTB ::Ignition and door locks for Safari
new or second hand? I will check with my key supplier see if we can get a new combination for you if you like.
W
W
williamhamilton wrote:new or second hand? I will check with my key supplier see if we can get a new combination for you if you like.
W
either or ?? depends on price i guess for new
- williamhamilton
tga_4x4 wrote:Looking for ignition with key and matching door locks for a Y60 safari please
What year is a Y60? I have a listing for Nissan Safari 1997-2000 (complete with switch, 'no push' type, non eccentric) and door locks are avail for that year range too. If I have the right year I will sort price for you.
W
williamhamilton wrote:tga_4x4 wrote:Looking for ignition with key and matching door locks for a Y60 safari please
W
Y60 is th GQ
Id say the listing you have is for a GU
keithal wrote:williamhamilton wrote:tga_4x4 wrote:Looking for ignition with key and matching door locks for a Y60 safari please
W
Y60 is th GQ
Yep sounds like Y61, Y60 goes upto 97
I assume Ign will be the same but cannot guarentee Once upon a time some bell end tried to steal my ute n wrecked a lock, I got a 2nd hand one cheap and off the top of my head it was 15bucks or so to redo to match my key. Apparently they can cut keys off the "code" on the Ign barrel so you dont need a sample, hope this helps assuming your not starting from scratch
Tarmac wrote:I assume Ign will be the same but cannot guarentee Once upon a time some bell end tried to steal my ute n wrecked a lock, I got a 2nd hand one cheap and off the top of my head it was 15bucks or so to redo to match my key. Apparently they can cut keys off the "code" on the Ign barrel so you dont need a sample, hope this helps assuming your not starting from scratch
No the wanks bloody wrecked the steering lock and door lock, mate is gutted
Theiven cnts should get their hands broken and not fixed/reset
, just my opinion. If you can acquire the 2 locks and ign without the key, you should be able to get 2 keys cut and door locks "fiddled" to suit the ign for around 60 bucks. Oh did I mention we should bring back stocks for thieves etc and just put down those convicted of "bad" crimes
If you dont find a matching set, just make sure a key goes into all locks, that way you can get them rekeyed to suit 1 key. Obviously they wont turn , but it means that they can all have the same key.
And if you do find a mis-matched pair, you could courier them to me, i will rekey them at work and courier back for free!!!
snork wrote:If you dont find a matching set, just make sure a key goes into all locks, that way you can get them rekeyed to suit 1 key. Obviously they wont turn , but it means that they can all have the same key.
cheers mate.. they are proving a little elusive to get ....
Tarmac wrote:Theiven cnts should get their hands broken and not fixed/reset, just my opinion. If you can acquire the 2 locks and ign without the key, you should be able to get 2 keys cut and door locks "fiddled" to suit the ign for around 60 bucks. Oh did I mention we should bring back stocks for thieves etc and just put down those convicted of "bad" crimes
Yes public stoning for more than thieves too, would cut crime down considerably i reckon
I will look at work tomorrow, see if i can get a set
snork wrote:I will look at work tomorrow, see if i can get a set
Thanks mate, appreciate it
