s14 silvia r200 into c200 navara?
For all Nissan related topics
Trench_rat
Post by Trench_rat »
does anyone know if a lsd centre from a s14 silvia r200 will fit into a c200 housing from a d21 navara? and also will the ring and pinion swap over?
slide
Re: s14 silvia r200 into c200 navara?
Post by slide »
Havent tried it, but knowing nissan yes they will "Fit". The problem I see is
that the viscous s14 diff uses two splines on one side axle (see picture), and so to fit in a c200 you would need to get an engineer to modify one side axle to have the second spline. Without the second spline the viscous diff will behave like an open diff.
BogBoy
Post by BogBoy »
Could you not just use the slivia stub?
KIWI_TERRANO
Post by KIWI_TERRANO »
Cv bolt pattern looks same as the cvs in my old girl
wsr4x4
Post by wsr4x4 »
Viscous diffs are useless anyway wouldnt bother
BogBoy
Post by BogBoy »
I have a r200 lsd out of a skyline, would that work?
Return to “Nissan”
