Best method to wreck/dismantle a GQ
As above.I have a 1990 LWB Safari that has roof rust issues that means no more WoF unless plenty $$$$ spent on it.
I need help regards the best sequence of dismantling.
Have 4 x heavy axle stands.1 x 3 ton trolley jack.Reasonable number of tools.
What else will be required to get job done?
Cheerz
Cheerz
- mudlva
Re: Best method to wreck/dismantle a GQ
Where abouts are you as i could give you a hand as im looking for a lwb chassis oh an engine crane to lift stuff around would be good i have one as well
20 minutes Sth of you cobber.
Looking to do the job when backyard dries out.
Xmas work break most likely
I can hire engine/gearbox crane/lift.
Suppose I will need some heavy duty pallets to place engine/gearbox on.
Have a rough idea of pricing from TM.
Cheerz
Cheerz
Those big chunky chrome babies.
I always sold the engine and gearbox first while the car was running so the buyer could still do a compression/leak down check /test, could also strip the interior out in the mean time to get rid of parts.
Good call nismo26.
That seems fair to the buyer.
Cheerz.
Cheerz.
Easiest way to me would be host up a wrecking auction on TM with photos and get people to ask for what the want then host auctions of the parts people what. After you've sold most of the big expensive stuff. Scrap it or sell the rest to a 4x4 dismantler maybe?
On another note, any chance I can buy the dash clock off you and some of the black switch blanks out of the dash? Also, what kind of sun visors does it have. (I'm after some of the shorter ones from a truck with a pitch/roll/altimeter on the roof)
Tomo
1991 Nissan Safari AD SWB TD42 - 33x12.5 BFG KMs, 2" lift + more coming.
"Never let a nerd loose with a torque wrench."
flog off the small bits first, interior doors lights trim / anything that cld be slow to move. With diffs trans eng etc there is always someone somewhere looking for it and it seems you have an idea on what its worth
- Suza
Dose it have the rear sliding windows? I am after a set with good tracks and glass for my LWB
easiest way to dismantle a nissan is a couple of sticks of jelly
- crazyclark31
sig wrote:easiest way to dismantle a nissan is a couple of sticks of jelly![]()
Sorry mate but that won't work
http://www.youtube.com/watch?v=mQKhle2jtH8
i will take the engine off your hands, assuming its a diesel..
The missing mudflap
- Driver/Navigator
Does it have the rear swaybar intact? if so can I have the drivers side disconnect mechanism? if it is a fixed non-disconnect type can I have the drivers side sawybar mount anyway?
- chopdpatrol
- Bush Crasher
