front lsd for a terrano
For all Nissan related topics
poss682
Post by poss682 »
is it possable to get a lsd for the front of a terrano from any other nissan and has anyone done this ?? i remember reading something about nissan zx rear lsd from somewhere ?
mud_slinger
Re: front lsd for a terrano
Post by mud_slinger »
use the search function it has come up plenty of times :wink:
needs more curry
0272593533
poss682
Post by poss682 »
could you link them because i cant find any ....
BogBoy
Post by BogBoy »
kiwipete
Post by kiwipete »
Ph 0212078472
Crash bandicoot
Post by Crash bandicoot »
R200 from a nissan silvia/skyline/turbo laurel or cefiro.
One thing ill give nissan, there model interchangeability is awesome
sibainmud
Post by sibainmud »
What about if you have an R180 front? Only some models came out with R200 fronts. It is a bit random but the post 94's had them.
Crash bandicoot
sibainmud wrote:What about if you have an R180 front? Only some models came out with R200 fronts. It is a bit random but the post 94's had them.
then you want the front diff from the early mistral/terrano II/ ford maverick... but not the facelifted one though with the TDI 'puter controlled 2.7, thats r200.
Crash bandicoot
come to think of it the 4wd SSS bluebirds and TE primera had that diff in the rear too.
BogBoy
Post by BogBoy »
Done and dragged lol
slide
Post by slide »
All v6 have r200, petrol and diesel 4bangers seem to all have r180.
Or do 94- diesels have r200 also?
slide
Post by slide »
Crash bandicoot wrote:come to think of it the 4wd SSS bluebirds and TE primera had that diff in the rear too.
Do you know if any had lsd in rear of these tho?
I believe the gtir pulsar had lsd rear r180. Havn't stumbled across any to disassemble and check out for compatibilty tho.
Also some subarus have r180 rear diff, I think some guys adapt these to go in datsuns to get lsd.
sibainmud
Post by sibainmud »
slide wrote:I believe the gtir pulsar had lsd rear r180. Havn't stumbled across any to disassemble and check out for compatibilty tho.
I have. The shaft needs the extension to engage with the clutch packs :(
Though i haven't tried the Pulsar cv to terrano comparison. I shall follow it up.
sibainmud
Post by sibainmud »
But do they come in 4.875:1 ratio? Or only 4.3?
Crash bandicoot
The GTIR and TE-egt were homologation production vehicles which ran the 4.8 something ratio...that was the good ole days of Group B rallying. going around climbing trees with 6-700 hp hatchbacks... not a very high top speed but they'd snap your neck getting to there top speed though. used to own one.
here is a genuine Tarmac special 4wd 2litre manual.
When the party pooping saftey eggheads said they were too dangerous for that aswell nissan just put them in the BTCC...enter paul radisich
BogBoy
Post by BogBoy »
My old rear wheel drive legacy came factory with a R180 diff but they are way longer than a nissan diff
Crash bandicoot
more to do with the carrier and the length of the pinion shaft. the actual business end of the LSD is what matters. the pinion and crown you want to suit the housing and carrier you want to use ,...the LSD/spider housing should be from the donor...
mud_slinger
as it happens i have a u13 lsd rear diff sitting on my bench in the garage if you are in chch you are more than welcome to come look at it and compare it to the front diffs of the rano but it is not for sale and i also happen to have a p10 rear diff for you too look at too which is in the vehicle, nothing a jack cant fix tho :wink:
needs more curry
0272593533
poss682
Post by poss682 »
http://forums.nicoclub.com/all-you-need ... 33955.html
says something about nissan zx lsds
Dirtydog
Post by Dirtydog »
for all its worth, wouldnt it be easier to weld front diff?
also, the zx rears are r200's.
just reading some more on it, if your in need of a r200 i may have one..
Tarmac
Post by Tarmac »
Go the r200 complete front end, opens up many options - bigger cv's etc
poss682
Post by poss682 »
so no one has done this modification ......
tweake
Post by tweake »
why lsd?
not to sure on terrano but there are lockers for r180 diffs. auto locker and arb.
poss682
Post by poss682 »
not as harsh as a locker especially with my really bad c.v angle
BogBoy
Post by BogBoy »
poss682 wrote:not as harsh as a locker especially with my really bad c.v angle
I have already found out how easy they snap......
poss682
Post by poss682 »
oh really with or without locker
Tarmac
Post by Tarmac »
http://www.navara.asia/forum. these guys cover nissan d21/2 front diffs well, stil unsure what the qd32 d22s got but have a feeling its the r200
poss682
Post by poss682 »
your link go's to to url not found
tweake
Post by tweake »
Tarmac wrote:http://www.navara.asia/forum. these guys cover nissan d21/2 front diffs well, stil unsure what the qd32 d22s got but have a feeling its the r200
r180 front h233 rear i think it is. zd30 same front but c200 rear.
poss682
Post by poss682 »
sorry im not sure what your saying here your link is still not working
Return to “Nissan”
