GQ turbo setup options
For all Nissan related topics
CLUMZ1
Post by CLUMZ1 »
Hello ORE,
I'm thinking I haven't got enough hair driers in my life. How many of you are running a TD42 turbo, how have you set it up? intercoolers etc?
I'm doing some research to turbo mine but have heard mixed opinions on how to set them up. So a pic/description and opinion of your setups would be awesome, budget is about $1500 completed.
Any recommended shops in Wellington for doing some of the work?
Cheese,
Adam.
CLUMZ1
Re: GQ turbo setup options
Post by CLUMZ1 »
yes no maybe (please print clearly)
http://www.trademe.co.nz/motors/car-parts-accessories/performance/turbos/auction-506107467.htm
Welcome to Off Roader
Why should you purchase our products over any other products in the market?
*Items sourced from Manufactures NOT Sub Suppliers overseas. (Meaning we request high quality products for you)
*We are a Business and a shop.
*We are open Monday-Saturday 9am-5:30pm
*Now open Sunday 9am-2pm
*Friendly, Professional, Honest and Dependable staff.
*We back all our products with replacement warranties 6-12 months.
*We are happy to answer any questions
Nissan Safari or Patrol TB42 or TD42 Turbo Kit. Suited for Y60
*Comes with
- Manifold
- Snorkel
- Turbo for external or internal use
- Rear flange
- 50mm Wastegate
- Turbo Oil feed lines
* What you see in the picture you get
* The manifold, turbo and wastegate will bolt straight on together
* Snorkel will fit onto you guard
* Oil line kit perfect for your turbo
* Rear flange to bolt up to the turbo so then you can weld your exhaust on!
A MUST HAVE FOR ANY SAFARI. To give that extra bit of power!
Fakey
Post by Fakey »
Pretty sure everyone's waiting for someone to say "search" an you shall find :mrgreen: it's been done to death on here an oz sites like patrol4x4
To be honest I don't think your $1500 budget will go very far even if you do everything your self :wink:
Didn't barbie drive a jeep??
rangimotors
Post by rangimotors »
do some searching on this website before buying anything, this has been covered a lot. There is a lot of feedback and info about that kit you have posted so do your home work. Caveat emptor.
IMHO you will not do it for 1500 even if you build it yourself. I'd put my money on having to replace your clutch as well.
Have a spare turbo like the one in the pic with blown rear seal
taz01
Tazzles
Post by taz01 »
CLUMZ1 wrote:Hello ORE,
Cheese,
Adam.
dude you walked past the almost complete unit today/last week next to the 4x4 porn on the counter............................sure 1500 will get you all the components labour will be abit providing the manifold comes off without breaking any studs or you can go j-pipe setup for abit less ......
WARNING:
crazyclark31
Post by crazyclark31 »
did my system myself.
Made a j pipe out 40mm steam pipe and bends $40
Second hand tdo5h plus rebuild kit $350
Oil feed hose and fittings $85
3in exhaust(no muffler)plus mandrel bends $250
Vairous flanges and gaskets $100
Crossover pipe and silicone hoses and clamps $30
nissan intercooler $25
flexy $50
Clutch(heavy duty) $450
Misc $100
Total $1480
this was all done with the basic of tools and lots of my time.
So if your getting someone to do it then add alot more $$$
Heres a pic. Looks rough but was very reliable and did the job real well.
tga_4x4
Post by tga_4x4 »
Cheese,
Adam.
I bought a LWB with the offroader kit fitted, the manifold is identical to a locally made one, the turbo i have been told not to go over the stock 7psi boost as they are a little weak in the bearing dept, but overall bloody happy with the way it runs, even with 33"s its a huge step up from a non turbo shorty on 31"s
crazyclark31
Cheese,
Adam.
if you spend the same money on a 2nd hand tdo5 and a rebuild kit as you do on one of those scarles turbos you'd be very impressed with the difference.Can up the boost to 15psi(Which imho every turbo td42 should be at min). Also get some reliability to go with it. Then watch it come alive 8) 8)
tga_4x4
Post by tga_4x4 »
TD05 with what size wheel, 16g or 20g ?? TD05 or TD05H ?
nismo26
Post by nismo26 »
Would only want a 16g unless you plan on getting the pump modded.
crazyclark31
without bigger plunger etc then can only really use the tod05 16g small wheel. You can run the big wheel 16g but without boost comp there would be a heap of black smoke and high egts while its building boost and it would have a bit of lag.
The 16g small wheels i've used on various setups have always reached full boost by 1900rpm max. normally around the 1700 mark.
Mate thought he'd be clever and put a 18g wheel one in and what a joke. full boost at 2700 under full load. and took ages to get there.
I'd monster him everytime we had a match off.
shaun.paddy
Post by shaun.paddy »
Would a tdo5 tdo5h or tdo5hr best fit the bill ... im not sure of the differences
crazyclark31
shaun.paddy wrote:Would a tdo5 tdo5h or tdo5hr best fit the bill ... im not sure of the differences
They all would. Yours is a tdo5h. It just means the have different turbine/compressor shapes. maybe also different bearings ie thrust or ball bearings.
Have found the tdo5h gives the best pull through the rev range
tga_4x4
Post by tga_4x4 »
Righto guys.. got a pyro fitted post turbo, not ideal but was the easiest place to fit it, pump turned up a bit, still dont see any smoke, full boost is around 2000rpm boost is set at 8 psi. pyro gets upto 480c going up steepish long hill, what to do to cool it down a bit...and yes i know i should do the 12mm plunger bit and anaroid, these will happen as funds allow
crazyclark31
with your kind setup an aniroid or bigger plunger isn't nessacary.
To lower the egts you can either wind up the boost or lessen the fuel. Personally i'd do the latter with the type of turbo you have.
Fyi you only need the bigger plunger when your standard pump has been or will be maxed out.
A pump aniroid only limits the off boost fuel so gain if theres not much smoke off boost then i wouldn't worry bout it either
tga_4x4
Post by tga_4x4 »
crazyclark31 wrote:with your kind setup an aniroid or bigger plunger isn't nessacary.
May try winding up the boost to 10 or 12 psi..if that fails i will wind the fuel back a tad, unfortunately i have no idea how much it has been turned up as it was fitted prior to my purchase, from memory shortening the rod ups the boost ?
motardbiker
Post by motardbiker »
Winding up the rod puts more pretension on the wastegate, more pretension does increase the boost level a bit but make sure you still have full travel of the wastegate lever so you dont spike or overboost
tga_4x4
Post by tga_4x4 »
Good point, I turned the fuel back a wee bit this morning, egt's look to have come back a little also, hard to say as it was a colder morning, not sure i really want to up the boost on the "scarles" turbo, untill i get the turbo internals upgraded
crazyclark31
good idea. from memory the garrett kits fit those turbos.
motardbiker
Cheese,
Adam.
Plan on spending a bit more than $1500, here is my setup so far
Manifold from Sinco customs (http://www.sinco.co.nz) $900+gst
Turbo from Scarles SCR320 model (http://www.scarles.co.nz) $600ish
Oil feed line $100
Oil Return line $50 ish, $20 weld on fitting to sump, $30 sump gasket
Air filter $70ish
Cross over pipe handmade $0
Silicon hose $30
Dump pipe, handmade, no exhaust yet......
This is what I'm running so far
So this setup, assuming you reuse your exhaust gaskets, have a mate to weld on the fitting to your sump, dont run a pyro guage or boost guage and connect to your existing exhuast system $1800 - $1900
The extras but not essential that I have installed or yet to install are, Boost Guage $50, Pyro Guage $130, Water to air intercooler $220, pump for cooler $150, Water to air intercooler radiator $70, 3"exhuast system $200ish
I reckon I will have spent around the $3000 mark by the time I am happy
Twodiffs
Post by Twodiffs »
motardbiker...how'd you get away with $30 sump gasket?
motardbiker
nzgaskets, first name basis at the local repco, it was $30ish so plus/minus $5
http://www.nzgaskets.co.nz/SetDetails.aspx?SetID=2642
Twodiffs
Post by Twodiffs »
Ta dude, will look into that...don't fancy paying $130 for genuine Nissan one :shock:
Twodiffs
Post by Twodiffs »
Got a gasket from Appco, i'm changing the sump over today.
Gregorys manual says to use 'jointing compound' on both sides of the new gasket before fixing in place.
Thats thrown me...do I need that stuff and what is it pls??
Taz
Post by Taz »
Twodiffs wrote:Got a gasket from Appco, i'm changing the sump over today.
Just a sealant like 'Gasket Goo'
Twodiffs
Post by Twodiffs »
Cool, i'll start putting it back together, was pleased to see no sludge whatsoever in the sump!
How long should I leave it before starting it? Suppose that depends on the sealant used.
and make sure you tighten in the correct order and tight
Twodiffs
Post by Twodiffs »
coxsy wrote:and make sure you tighten in the correct order and tight
Don't you be saying things like 'correct order' :shock: :P Book just said progressively so I nipped them up in an alternate even pattern, then tightened them up as per how they felt when undoing them. Bible said 6-7Nm but my torque wrenches start off at 15-19 or so. Filled it up with oil and i'll let it sit overnight before starting it tomorrow.
Finally got my first beer down ma throat :P
yer follow the book , easy, yer right. some are in nasty places gearbox end
Return to “Nissan”
