kzj78 engine options
hello24
Post by hello24 »
disaster this weekend the 1kz has done its head, hoping its just a gasket.... :( the current 1kz has done over 500000ks on the clock so if i were to keep it would prob be looking for a fully reconditioned engine or second hand with low ks but price of these even on trade me make a engine swap to lexus or v6 commodore look very tempting.. i am very interested in the commodore v6 as i have had one in a hilux and lovedit, and the fact that they are so easy to get ahold of so i wouldnt feel as bad thrashing it. have heard some rumours about a bighorn v6 bell housing mateing to the prado auto and commodore v6 if any one has any experience on this would you shed some light on the ins and outs of it?
the lexus seems to be a popular option but dont like the complexity of the engine saying that have been in a couple luxs and they do sound great.
how easy are these conversions? any help much appreciated
Re: kzj78 engine options
chuck another 1kz in with a manual pump and intercooler and dump pipe
madlux
Post by madlux »
Jerry wrote:chuck another 1kz in with a manual pump and intercooler and dump pipe
yep 8)
hello24
Post by hello24 »
has intercooler, water injection, chip, 20psi, 2.5" exhaust but dont want to spend thousands for it to happen again and wish i had done a engine swap?
with another motor ie commy 1uz etc you have other costs wiring adaptors cert, with a 1kz its just a replacement ...
work out the cost of a rebuild compared with the costs of a converson
just my 5c
juz
Post by juz »
stick with the 1kz, rebuild will be worth it. Even new heads are cheap enough now days, Used to be $2500 just for the head, now I think there $1000.
crazee
Post by crazee »
Just been down the road of a commodore v6 into pardo cant use bighorn transfer as pardo has off set rear diff so either have to make adaptor for between gear box/auto and transfer or like i did motor and auto. So running stanted running gear with commmodore v6 in front of pardo auto and 35s goes well bit of trouble sorting ecu's as auto has one .Your welcome to come have a look and a drive to see what you think only difference is mine is a 71 so swb
micahb
Post by micahb »
Just stick with the 1kz. if you want it to last longer, get a more efficient turbo for the boost your running. better the engine you know and all ready set up for...
Just need to remember when you drive it, it aint a lexus v8, its a diesel!
hello24
Post by hello24 »
ok have started the install! have chosen an ecotec 3.8 commodore. for the fact that they are so easy to get parts for and are just a bulletproof motor. have motor bolted up to the gearbox with minor mods to the tc to fit the holden flexplate. engine fits in engine bay perfectly using a rodeo ra bellhousing to mate the v6 to the toyota auto. i will be manulising the auto using calvin's instructions and will be getting on with engine mounts some time next week. will upload some photos of the progress.
hello24 wrote:ok have started the install! have chosen an ecotec 3.8 commodore. for the fact that they are so easy to get parts for and are just a bulletproof motor.
yeah mate good choice of motor and cheap as chips if you ever need to replace it :D , just be aware they have a shallow mid bowl sump so its really easy to get oil starvation and that all familular knock knock knock noise when your putting the truck through angles or steep hills off road :x Image
hello24
Post by hello24 »
i dont know yet but i may have to change the sump if its in the way and somthing for me to look into if im going to be changing it cheers
1justin
Post by 1justin »
hey mate what are you doing with chip and injection kit also is it a top mount intercooler got a 3rd gen surf with a 1kz starting to look for those sort of bits for it
tallsam66
Post by tallsam66 »
What are you doing to adjust for the diff rev range of the petrol as opposed to the diesel.
hello24
Post by hello24 »
sorry mate alot of the good stuff sold......
ratios..... well plan was to slap the motor in and see how it goes. im manulizing the aoto at the moment so that will give me a good idea of what reves its doing in 4th but had my fingers crossed that i wont have to change the gearing but time will tell
evolution02
Post by evolution02 »
Would love to know details like how you connected the engine to gearbox and what you have done to the auto? Also what are you doing for engine ecu? Using a link Ecu? And maybe some pics when your done
Thanks
hello24
Post by hello24 »
will post pics soon engine is sitting in engine bay ready for wiring engine mounts are custom made but the bellhousing is from a isuzu rodeo that mated the commy v6 to the toyota gearbox perfectly...... future plans will be to install a sc 3.8 but in the mean time will see how it goes... will have pics up soon
Return to “Toyota”
