So before somone pipes up... yes ive checked and no its not a blown bulb passenger side is the one not working. ive got 24v at driver side and only 3 or 4v at passenger. any suggestions? or better yet solutions! Cheers.
check the relay under the dash above the fuse box. And all the plugs/earths. had that issue before(in that truck) and found it was the relay. Check the fuse to
The terranos have a nasty habit of burning contacts in the switch. I would not be surprised if safari has the same design switch, and therefore the same problem. If bulb is all good, switch would be the 2nd place to look
my last safari did this and I replaced the fuse and it was all good. the fuse itself looked all good but when I put a test light on it one side was bright and the otherside was only a slight glow.
thanks for all the suggestions, seems to have been something to do with the fuse.... i didn't replace any, just pulled them out and checked em and whatdya no... all go. must have beencovered in crap and shorting out? thanks again!
