LJ Project "Rangi"
For all Suzuki related topics
UBZ
LJ Project "Rangi"
Post by UBZ »
So I needed something to beat around in the bush , something that I didn't need to care to much about the panel work .
So project "Rangi" was born
So word went out on the Local LJ network and a suitable LJ50 was acquired .
l
The Plan as it stands .
LJ50 Chassis / Tub (whats left of it) / Roll cage
LJ80 Diffs (spring perches moved to LJ50 Spacing)
SJ410 Transfer Case ( with aftermarket reduction gear set)
Suzuki F10a 970cc Engine and LJ80 4 speed gearbox.
Rear Mounted Radiator
Front and Rear disc breaks
Rear Lockright auto locker
9000lb winch (rear mounted)
7.50x16 SAT (32x7.5x16) mud tyres on modified factory 16" rims
I all ready have most of the parts , so hopefully this will progress quickly
the Bottom of the tub has the standard dipped in acid dissolving coke can action going on , has been "Rangi" repaired by pop rivitting some sheet metal in where the floors were and the rear has been chopped off .
Some of the more interesting features
The Origional LJ50 3cyl 2 stroke and gearbox, that is going to DB as spares .
Awesome super advanced ultra air cooled , fiddle break plumbing - these will be removed
The Plumber Snorkel
Rear Tray Removed
Engine Stripped out
LJ80 Axle and engine mount Donner. - Chassis has major rust issues
lincooln
Re: Suzuki LJ Project "Rangi"
Post by lincooln »
looks like a cool project.
Lubrication Specialist
Lubrication Engineers
imsohi
Post by imsohi »
awesome looking weapon should be some fun when your done
PuddleJumper
Post by PuddleJumper »
Yay! Another LJ - Will be watching! 8)
DieselBoy
Post by DieselBoy »
I worked out that LJ's been sitting in my shed for 5 years looking for a purpose in life!!!!
Wooot can't wait to see its reincarnation :mrgreen: :mrgreen: :mrgreen:
UBZ
Post by UBZ »
DieselBoy wrote:I worked out that LJ's been sitting in my shed for 5 years looking for a purpose in life!!!!
only 5 years :lol: :lol:
Was definalty fun "driving" it around the paddock :lol:
LJ80 Donner front Diff - just a little green
will only be using the Housing , Diff head and Axles.
BlakeJ
Post by BlakeJ »
oooo is this the kati kati or keri keri storage LJ from DB's shed, awesome to see it being fixed up
UBZ
Post by UBZ »
BlakeJ wrote:oooo is this the kati kati or keri keri storage LJ from DB's shed, awesome to see it being fixed up
Yep its the Katikati LJ .
A little bit of progress
Got both the front and rear doner Diffs stripped down .
Rear Diff Housing is toast , so the LJ Network comes to the rescue again with a usable housing .
Front Diff Head is in Mint Condition .
Rear Diff Head is a bit dirty , but with a re-bulid will be fine as R&P are still sweet.
but Im proborby not going to use these diff heads know as im looking at putting 4.88 LJ50 R&P into 410 Carriers for better gearing .
One Front axle is going to need a sleeve where the seal runs
Rear axles look ok , just need new bearings .
mercutio
Post by mercutio »
I have a spare F10A sitting around left over from my little Suzuki it is one of the SC100 coupe engines so apparently has an extra 2 HP due to factory head work. It needs the headgasket replacing and it has a set of bearings rings and gaskets with it.
UBZ i'll give you first refusal.
my 4wd is not a truck
jervisad
Post by jervisad »
:lol: whens the next update on this thing it looks like it will be a mint little truck
UBZ
Post by UBZ »
alot going on. alot getting chopped n glued
Farkn broken welder till the weekend :evil: :evil:
zukmeista
Post by zukmeista »
:shock: If you are keen enough to be fixing that can you do the SJ410 too?! :D
UBZ
Post by UBZ »
zukmeista wrote::shock: If you are keen enough to be fixing that can you do the SJ410 too?! :D
Feeling rich are we :lol: :lol: At least 50hrs work in that ...........
I told you before , go buy a $300 mig welder and teach yourself to weld . Dosen't need to be pretty if you start learning on the bits that will be hidden.
Once you master welding zuk panel steel , everything else is easy.
DieselBoy
Post by DieselBoy »
UBZ wrote:Image
I see a super bling chassis and running gear under that!!!!
Priorities :D :D
Big-AL
Post by Big-AL »
UBZ wrote: Dosen't need to be pretty if you start learning on the bits that will be hidden.
Or the bits that get hit with a grinder after the weld :D
UBZ
Re: LJ Project "Rangi"
Post by UBZ »
Rangi is rolling on 4 wheels finally ......... :mrgreen:
Just a little bit of trimming of the body work required :roll: :lol:
Check out the pumpkin clearance :twisted: more clearance on 32's than a Hilux on 36's
zukmeista
Post by zukmeista »
Those tyres look farking massive on it! :shock: This thing will kick arse offroad when you finish it. 8)
UBZ
Post by UBZ »
12 years later ……..
Rescue Mission on Armsup
mercutio
Post by mercutio »
Nice one :mrgreen: :mrgreen:
DieselBoy
Post by DieselBoy »
Wow, no like button. This is good, I need to actually write a comment :D :D
Awesome to see it move, now to get it across to the Sth Island :lol:
UBZ
Post by UBZ »
lilpigzuk
Tiger Balm
Post by lilpigzuk »
Wahoo!!!!
mudsurfv6
Post by mudsurfv6 »
Now the work starts.
Andrew 0272226292.
UBZ
Post by UBZ »
Let’s just say the wife was less than impressed with my project arriving home .
Something about a pile of junk. :roll:
mudsurfv6
Post by mudsurfv6 »
She doesn't understand.
Andrew 0272226292.
UBZ
Post by UBZ »
For those interested , the hours of work that never gets seen .
UBZ
Post by UBZ »
Pinnacle LJ factory ish axle setup , all Suzuki
LJ50 Chassis - Narrow spring spacing
LJ80 housings - perches moved to LJ50 spacing
4.88 LJ50 Ring and Pinion
410 side gears and lockright in rear
Soft old SJ410 springs
Factory shackles with rubber bushes
SJ413 Hubs and stubs
Vitara rotors and calipers - front
SJ313 rotors and calipers - rear
Vitara fixed drive flanges
SJ410 Tie Rod
Cut and shut LJ80 / SJ410 draglink .
lj80 front and rear axles (front to be replaced with custom)
SJ410 CVs
Poor transmission mounts have not held up well . 0km on these !
Might need to tweak the brackets a little… to get thing sitting a little better aligned . Gearbox is currently sitting on the cross member . :poke:
UBZ
Post by UBZ »
In true ranga fashion …… he runs .
UBZ
Post by UBZ »
Brake work next
Some bling (LWB Vitara vented routers to suit the calipers all ready up front)
Also made a start on the master cylinder . Love the quality of the build on these old parts , feels good bringing them back into service again. Looking like just a good clean a reassembly is all that’s required
Then turned my hand back to glueing LJ tinfoil.
Practice on the rain collector first.
UBZ
Post by UBZ »
Rebuilt the master cylinder , not to difficult, just needed a good clean and reassembly .
Then got to fabbibg up a mounting frame and straps for the fuel cell from bits of an old boat trailer and left over flashings from the house
Next is to pull the body off and sort the last of the chassis welding , and fit new hard lines for fuel and brakes
Return to “Suzuki”
