castor correction
brakes-shocks-lockers-etc
ant-neil
castor correction
Post by ant-neil »
what would be the cheapest or simplest kit or way of doing this
i have a 96 disco with about a 3" lift
Crash bandicoot
Re: castor correction
Post by Crash bandicoot »
Could use offset bushes but they wont work at full articulation anyway.
better to get the suspension geometry changed by way of custom/ aftermarket parts and employ conventional bushes.
ant-neil
Post by ant-neil »
super flex arms are suposed to correct ya castor, but any idea on price or availabiltiy or similiar,
how do castor correction bushes work
Crash bandicoot
the centre hole is oliptical and can change the geometry depending on the position it is placed in.
Pedro
Post by Pedro »
ant-neil wrote:what would be the cheapest or simplest kit or way of doing this
don't the swivel housing bolt onto the diff?, could you not get the bolt holes slotted to allow rotation to correct angle? only issue could be the steering gear fouling the diff head, but i think the rear would go down away from that problem.
Pedro
oldyella
Post by oldyella »
I've got castor correction bushes in my disco suspension under my series 2. It has reduced the suspension articulation but drives fine. I plan to go to castor corrected aftermarked suspension arms from the UK long term.
Pete
Ralfie
Post by Ralfie »
Caster corrected arms for LR's are available in NZ together with cranked trailing arms as well.
ant-neil
Post by ant-neil »
what should i budget on for caster corrected arms
how hard would it be to just drop the chassis mounts down a couple inches
is it possible?
and would it work
Ralfie
Post by Ralfie »
Caster corrected arms were about $600 when I got them.
You could drop the rear mounts but a lot of work to get right and then they hang down ready to catch anything when off road.
I reckon not worth the hassle, go for corrected arms.
pressy
Post by pressy »
not sure of the disco set up? but my vx i got ironman caster correction plates easy to fit too... 8) 8)for a 100mm lift
Big
Post by Big »
I believe that disco arms can be bent to help with caster and will be ok.. unlike toyota arms which cannot be bent.. worth a search.. :?:
ant-neil
Post by ant-neil »
disco one some i tink most have have cast front arms and steal tube rear
castor correction plates look simple enough
and ya wouldnt loose any articulation like castor correction bushes
i might have to look that up
cheers guys
ant-neil
Post by ant-neil »
had a look and the two castor points are a fair way apart but im gonna have a pay and might try knock some up at home and see what they do
