Cheers Trent
BlakeJ wrote:make a rock lobster or buy the low range gears for it, i belive this is the one
http://www.lowrangeoffroad.com/index.ph ... gears.html
takes heaps off low range and 12% off high range, you can also make one yourself by machining 413 and 410 gears and swapping the output gears, but this kit has everything if you dont want to venture with that yourself
BlakeJ wrote:http://www.lowrangeoffroad.com/index.php/suzuki/sidekick-tracker-x90/drivetrain/sidekick-tracker-vitara-4-24-1-rockmonster-transfer-case-gears.html
this might work out a bit cheaper
