I know the stud pattern is the same, is the offset the same or is it close enough that a factory Nissan Safari rim will fit on a LN106 Hilux?
I recently purchased a 1989 LN106 hilux, it does not have factory steel wheels and as Im still 'broken' after a motorbike accident I cannot take them off to see what markings they have on them or and try the spare on etc.
The spare is a factory rim with what looks like an unused factory tyre that is way smaller than the 31x10.5x15 tyres I am putting on the Hilux.
The Hilux came with worn 32x11.5x15 tyres that I am replacing next week.
I have a spare (3/4 worn) 31x10.5x15 on a Safari 15x7 rim that I was using on my Pajero.
My question can I use the Nissan Spare for the Hilux or do I need to have the 31x10.5x15 tyre put on the Toyota rim.
If it needs to be done I will get the spare tyre swapped over when Im getting the new tyres put on.
Will a 15x7 Nissan Safari rim fit a ln106 Hilux?
- northland_pajero
- firestonecruiser
Re: Will a 15x7 Nissan Safari rim fit a ln106 Hilux?
yes it will fit
- northland_pajero
Thanks for your reply, that will save me some $$$
- firestonecruiser
just double check the centre hole that locates on hub and make sure no tierods will hit.
- northland_pajero
Will get the tyre shop to check that for me, the motorbike accident broke my left collar bone and right hand, so I can't change the tyres.
I'm pretty sure the safari has a smaller center hole, so it won't go. Stud pattern and offset will be ok. I can check at work tomorrow if you like....
- northland_pajero
Hadn't even thought about the centres so have measured the hilux spare and safari rim, both have 110mm diameter centres so that shouldn't be a problem.
I can work a tape measure just can't lift a tyre .
DEATH_INC wrote:I'm pretty sure the safari has a smaller center hole, so it won't go. Stud pattern and offset will be ok. I can check at work tomorrow if you like....
Toyota have the smaller centre bore, 108mm I think, Nissan is 110mm.
Flatmates factory saf 15x7 rim hits the tie rod ends on my 85 hilux. The inside wheel weights that is.
