The Zuk has gq diffs under it and 4" lifted prado coils,when the back flexs up the coil stays on the diff and comes away at the top from the body,if I hit anything at speed this can cause a spring to pop out,not ideal.but what I want to no is could the coil be to short,if it's flexing up to the max should that coil still be touching the body and not dropping?
Rich
