oricom uhf 088 radios at repco
they have the 80 channel uhf 088 radios for $219 full size radio fitment, seems pretty good at a good price if anyone needs one.. i bought one today.
Re: oricom uhf 088 radios at repco
Have you tried this yet muskie,I see there on special again might grab one too.
I bought one of these a few weeks ago ,seems to work well ,channel selector on the mike and radio ,80 ch ,seems to have a better range than my old uniden although that was approx 5 yrs old .
Cheers monstr I think I'll grab one too.
- Suza
So do these have the PRS channels in them
yep 80 prs channels
Were do you get an aerial and can it be fitted anywere or is there a better spot.
klompy wrote:Were do you get an aerial and can it be fitted anywere or is there a better spot.
Somewhere flat like the roof (ideal) or side of the bonet. Can mount on bullbars but the forward range isnt as good. Not to sure where you would get radio gear from in rotorua but try dicksmith, if they dont do radio stuff they might be able put you on to some one that does
hamboy wrote:klompy wrote:Were do you get an aerial and can it be fitted anywere or is there a better spot.
It also depends on whether it is a ground dependent or ground independent aerial as well
